65 Jetstar 88 Converting to power brakes
65 Jetstar 88 with 4-speed manual trans....I'm Converting to power brakes
I want to put power brakes on my 65 Jetstar 88 but I have run into a problem. I got the booster and master cylinder out of a donor car but the problem is my clutch rod that goes from the clutch pedal through the firewall to the Z-bar hits the booster. I don't see any way that a power booster will clear this rod. Does anyone know if 4-speed cars had a different booster than automatic cars? Were power brakes available with 4-speeds? any help appreciated!
Pictures would be great! I took the booster out of a 65 Jetstar 88 4-door with a 330, 2-speed automatic, and a 2 bbl carb. The booster looks the same as my Jetstar I and my other Jetstar 88 coupe, but both of those cars are automatics.
I am guessing that either they run a different booster with 4-speeds or a different clutch rod with power brakes. I really appreciate your help!
Thanks for the pics! Wow! that is completely different than my automatic cars! The boosters for automatics mount flush to the firewall! I bet I won't have any luck finding a manual trans brake booster either! Looks like I am keeping manual brakes!
I really appreciate the help!
Tony
Tony
delta254
Brakes/Hydraulic Systems
January 27th, 2013 08:11 AM
1969cutlazz
29
December 31st, 2012 05:22 PM
KZ442
April 10th, 2009 03:16 AM
