64 Jetfire Exhaust options
What are my exhaust options, can I run headers and duals?
I was gonna post a reply on my original post but I cant add to it.
https://classicoldsmobile.com/forums...tar-88-ct.html
RocketRaider stated:
"Just remember that a Jetstar 88 shares more mechanically with a Cutlass or even a Chevrolet than it does with the other 1964 full-size Oldsmobiles. OTOH that means it's often easier to find mechanical parts for it. Body and interior-wise it's the same as a Dynamic 88."
I was wondering if headers designed for a Cutlass would fit?
Thanks,
Joe
Thanks,
Joe
Thanks,
Joe
Thanks,
Joe
What this means is that Cutlass headers will not fit. The biggest problem is the rear steer configuration of these cars. On the J88 (and all full size through the 1970 model year) the steering linkage is behind the crossmember. On the A-body cars it is in front. This means that the space for headers is completely different.
Thanks, for the info Joe.
I guess the stock exhaust manifolds will have to do.
I noticed off the drivers side manifold the exhaust pipe connects to the passenger side manifold then then out of the passenger side manifold the the exhaust continues back. Has anyone tried blocking off the passenger side inlet and routing the drivers side exhaust out back and just have piping bent to create a separate dual exhaust?
Thanks,
Joe
Thanks,
Joe
Any 330/350 Olds factory eqipped with dual exhaust has a block off cap on the rh manifold.
Henry
Henry
Cool!, thats what I'll have to do.
Anybody got a pic of what the factory block off cap looks like?
That way if I run across one at a swap meet I'll know what it is.
If I cant find one I'm sure I can make something similiar.
Thanks,
joe
Thanks,
joe
The factory cap simply looks like one of the exhaust pipe flanges with the opening blanked off. Most people simply cut the last inch or so off the crossover pipe, weld a plate to the end, and bolt it in place with the stock flange.
