56 olds no spark
56 olds no spark
Distributor was converted to a pertronix electronic unit and is using a pertronix coil. I have power to the coil on both sides but i am getting no spark. There is an orange wire with a plastic connector on it that comes out of the firewall in that area but I havent been able to determine what it is for. I am thinking that is my issue but idk. I was thinking it may be for some kind of resistor. Any help is aprreciated.
No spark
Have you checked with a volt meter that you are indeed getting a full 12 volts? Did you bypass the voltage drop down resister,although they will run on 8 volts some have a hard time starting. And x2 on the rotor being left out.
I would start by working backward with a volt meter and isolate where you lose your juice....Tedd
This car was a project I bought and it has not been run since before I bought it. But the motor is rebuilt and the previous owner installed the pertronix kit. There is a rotor on there. I checked the coil with a multimeter and I am getting 12 volts at the coil. But i noticed the negative side has juice too. Should the negative side be getting juice too? I even un hooked the wires on the negative side and it still gets juice when the pos. side is hooked up.
You will read 12v on the negative side of the coil as it is looking for a ground to fire. Is there 12v on the positive side as you are cranking the engine?
It may be your pertronix is not wired correctly. I believe its a 2 wire connection for the distributor. Red goes to coil positive black goes to coil negative. There is I believe a yellow wire that runs from your starter to supply 12v during start to coil pos. And there should be a resistor wire that supplies approximately 8-10v during run. The resistor wire needs to be bypassed to get a full 12v @ run.
i had a similar problem a while back afetr i reinstalled my motor seems as though when i took my dist. apart to clean and lubricate after years of not being serviced. when i reinstalled everything and tried to fire it up i had nothing long story short i had left out a small groung wire within the dist. above the breaker plate. as soon as i put it in it fired right up. just a thought just 2x check wiring within dist.
i may just replace the pertronix unit and see if that does the trick but for now the project is halted. My DD ('96 Lt-1 Camaro) just broke down. I had a misfire a couple of months ago and by the time i got to the nearest shop to have it scanned, the raw fuel over heated my cat and it went bad. I fixed that misfire, it turned out to be a faulty new outta the box plug wire. Now it just started misfiring again and it threw a P0300 code which is for random/multiple misfire. Money I got is getting tied up in this right now. I will keeping looking over the wiring in the olds though.
AudioScape
August 23rd, 2013 09:23 AM
84oldsDelta88
September 11th, 2012 08:45 AM
