1941 Olds drive shaft
Old June 28th, 2015, 03:07 AM
rkiddo41olds
Robert Kiedrowski's Avatar
I have an Olds hydromatic and find almost no free space between the ujoint and rear end. I am used to sliding the drive shaft on to the trans spline
and sliding it back for a bolt up. Am considering shorting the drive shaft.
Any ideas?
Robert Kiedrowski is offline
Old June 28th, 2015, 05:22 AM
Ozzie's Avatar
Before doing the shortening, be sure that the engine/transmission has not moved rearward or that the rear axle has not moved forward due to some error. Also try to verify that someone has not substituted a part which would lead to the condition. The "open" driveshaft vehicles usually have sufficient movement so the driveshaft doesn't push on the transmission. I have a '55 with a Hydramatic and there is sufficient "slide" on the transmission's output shaft. I don't have the shop manual for the '41 so I'm a bit unsure if it is different.
Ozzie is offline
C.oleson
February 17th, 2014 04:29 PM
Frogge467
March 24th, 2012 11:09 PM
starfire_62
Drivetrain/Differentials
February 18th, 2012 12:30 PM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
rose
February 24th, 2009 10:42 AM
Quick Reply: 1941 Olds drive shaft
