proper driveshaft length
When I bought my '68 442, it had a 350 smogger motor and a turbo 350. I'm getting close to installing the 455 and a short shaft turbo 400. Now I'm wondering if the driveshaft may not be the original either. The shaft has a tube length of approximately 52.5 inches. Does anyone have the correct measurement?
Also, I moved the cross member to the furthest back position... is that correct?
Thanks...
Thanks...
Yes you have to move the xmember to the rear approx. 6 inches. I like to measure the distance and have a driveshaft made for your mod. I separate the yoke, slip it into the trans, push it in all the way, then slide it back 3/4 of an inch. Then measure from the center of the Ujoint hole on the yoke to the center of the Ujoint on the rear end.
The factory service manual probably specifies the length for a 442, which SHOULD match what you are doing, but why not just do the above and get it right for sure? In case the rear end differs or whatnot.
I also recommend using center of u-joint to center of u-joint for the critical measurement. Any driveshaft shop can do you a nice new one easily. Be sure to note how the u-joint attaches at the rear end- c-clips inside the yoke probably. Measure the yoke recess diameter for the UJ caps and the distance from outside edges of c-clips, to ensure you get the correct U-joint and/or shaft aft end.
texasred
Drivetrain/Differentials
April 27th, 2012 07:28 PM
