Installing new Axles
Old March 5th, 2019, 06:05 PM
rick442's Avatar
Hello All,
This is my first experience installing. Am I supposed to tap this in? The retainer plate is about a 1/4" from the axle plate.
I just want to make sure.
rick442 is offline
Old March 6th, 2019, 08:18 AM
I have always tightened the bolts/retaining plate to push the seal into the end of the axle shaft.
Fun71 is online now
Old March 6th, 2019, 10:04 AM
rick442's Avatar
Thanks Kenneth! Monzaz helped me as well. They pulled in.
rick442 is offline
Old March 7th, 2019, 04:03 PM
monzaz's Avatar
spacer plate
You need the spacer plate between the flange and the retain plate ...it acts as the backing plate thickness...They come in most disc brake kit and are for the bolt in axle rears BOP usually.
I have extra plates here if you need as they come in c-clip disc brake kits so I just save them.
YOU MUST have this spacer plate in or you will ruin the seals.
monzaz is offline
Tims68Olds
Brakes/Hydraulic Systems
March 11th, 2020 09:32 AM
Natedawg
Drivetrain/Differentials
June 17th, 2019 05:22 PM
Moses
June 11th, 2011 12:58 AM
Moses
June 10th, 2011 09:37 AM
oldzy
March 3rd, 2011 07:15 PM
Quick Reply: Installing new Axles
