83 Cutlass Supreme rear end mods
Old July 7th, 2004, 11:29 AM
<George>
Guest
Posts: n/a
Question
I've done a little research and called a few shops. I need to know if you can put a 3 series ring and pinion in a 2 series case by adding shims. One person that I talked to said he would have to order whole new diff. case to fit my desired 3.23 or 3.42 ring and pinion in the stock 2.41 case. It's a GM 10 bolt, 7.5. Thanks for your help.
Old July 12th, 2004, 11:00 AM
Past Administrator
Oldsguy's Avatar
Post
George, if you don't get an answer over here after a while, try Realoldspower.com. There are a lot of very knowledgeable guys over there that visit the site every day. If you post the question there you will get an answer. I can't help you other than that.
Oldsguy is offline
Oldskool84
January 13th, 2015 09:57 PM
350TurBRO
September 12th, 2014 11:52 AM
krooser
January 17th, 2013 10:15 PM
cspataf
July 31st, 2012 10:42 AM
m_tanner_75
December 28th, 2008 02:06 PM
Quick Reply: 83 Cutlass Supreme rear end mods
