70 Supreme Gear
Old August 16th, 2003, 10:55 AM
70Supreme's Avatar
Question
Question:
I have a 1970 Cutlass Supreme with the "o" type 12 bolt differential & and a 2.60 gear. I want to increase that to a 3.42 gear with Posi. Is that possible with off the shelf parts? Anyone with some practical experience who would be willing to post some options, I would appreciate it.
Later upgrade will probably include a trans with overdrive.
Thank you
70Supreme is offline
Old August 18th, 2003, 06:37 PM
70ragtop's Avatar
Post
It's more likely that you have either the 2.56 or 2.78:1 rear as Olds did not use a 2.60 in 70. There is much debate about the "O" type rear ends. I am no expert in this arena, so I'll refer you here:
Try the Olds FAQ for more info: http://oldsjunction.classicoldsmobil...ential%20Codes
And contact Supercars Unlimited.
www.SuperCarsUnlimited.com
Supercars Unlimited
8029 A SW 17th
Portland, OR 97219
PH: (503) 244-8249
FX: (503) 244-9639
70ragtop is offline
Old August 19th, 2003, 04:24 AM
70Supreme's Avatar
Thumbs up
Thank you! I have found that confusion as well. It looks like I will need to count splines on my axel to confirm exactly what I can fit in the carrier or if I need a new carrier.
rossdev
April 2nd, 2015 02:13 PM
drjr56
September 9th, 2012 08:05 PM
Crayon Scribe
April 7th, 2012 04:44 AM
misterthews
Drivetrain/Differentials
September 14th, 2011 03:20 PM
Chuck C
September 5th, 2007 02:35 PM
Quick Reply: 70 Supreme Gear
