67 Delmont 88 to 8.5" Caprice Differential
Old November 6th, 2016, 05:40 PM
Delmont 88 PA's Avatar
I have a 1967 Delmont 88 with a 455 and a 4 speed manual. The rear is a 9-3/8" O-type posi with 2.73 or 2.78 gears. It is in good shape but it's a bear to pull out with (since the cam is larger than stock).
I can get an 8.5" 3.08 posi for $350 from a 1993 Caprice police car. It's my understanding that this rear will bolt right into a 1967 B body.
I am concerned that this rear rear will hold up to a slightly built 455. Has anyone done this?
Also, has anyone started making gears for the big O-type rear yet?
Thanks,
Chris
Delmont 88 PA is offline
Old November 14th, 2016, 04:02 PM
monzaz's Avatar
Rear end issues.
Thanks,
Chris
WRONG.... Will not even be close to fitting... Shocks are in the wrong spot, lower control arms wrong, spring perches wrong, anything else ?
Just remove the BIG cam and recam with a good smaller torque cam
260-268 duration cam
monzaz is offline
Old November 16th, 2016, 05:43 AM
Also, as far as I know there aren't any aftermarket gear sets for these differentials.
Olds64 is offline
Old November 16th, 2016, 06:48 PM
monzaz's Avatar
tHESE DIFFERENTIALS WOULD BE REFERENCING THE oLDS fULL SIZE CAR REARS 12 BOLT COVER 12 BOLT RING.
Buick 9.3 is another rear that is totally obsolete to aftermarket parts too.
Pontiac 8.875 is the only FULL size rear from the 1965-1970 era that has a gear set in the aftermarket being 3.55 gear sets.
Pontiac and olds do share the Pontiac rear - The low HP Olds got the Pontiac 8.875 rears so there is that option if you need a solid big car rear.
I have a shelf full of posi units and 3-4 sets of 3.55 NEW gear sets.
Now the problem is that is all expensive stuff. LIKE most of the big car stuff.
Jim
J D
monzaz is offline
Old November 17th, 2016, 05:32 AM
That's cool. I didn't know that there were aftermarket parts for Pontiac differentials. The B/C body Oldsmobiles are under appreciated.
Olds64 is offline
Old November 17th, 2016, 07:43 PM
monzaz's Avatar
I do not know about that
There are just non left... Jim
they got derby-ed to death
monzaz is offline
Old November 18th, 2016, 05:44 AM
Olds64 is offline
Old November 19th, 2016, 11:05 AM
Thanks!
I have a posi 2.73 or 2.78 but could use gears. Will 3.55's fit in that unit? If I remember correctly from an earlier post, 3.24's are the lowest that will work in the 9-3/8" unit with 2.7X's. Since I don't race the car 3.24's would work although 3.55's would be even better.
Have any of you guys put in an aftermarket rear that has the same spring and shock perches as well as trailing arm connections as the B body that would take a Ford 9"?
Dead Reckon
May 7th, 2014 09:35 PM
L77F85
Drivetrain/Differentials
16
November 29th, 2013 06:19 AM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
72droptop
February 11th, 2009 06:38 AM
Quick Reply: 67 Delmont 88 to 8.5" Caprice Differential
