1968 HD 31 spline diff
I have a 1968 O axle HD 31 spline posi diff and I'm trying to replace the 3.90 ring and pinion with a higher gear ratio but can't seem to find anyone who makes a ring and pinion for that rear. I would be happy finding a good used set if I can't purchase new. Anyone have suggestions? Thanks, Jay
Fyi
Your factory gear is a 3.91 not a 3.90. That OEM posi carrier can be used with OEM 3.42, 3.91, 4.33, 4.66 & 5.00 gear sets. There are no aftermarket gear sets for your carrier. If you want to go to 3.08 or 3.23 gears you will also need to change your carrier. The aftermarket 3.42 gears are made for the 3.08 / 3.23 carrier but wont work on your OEM carrier.
Best bet is a wanted ad for used gears of your choice & a carrier if mandated by the gear choice.
You can't physically put a lower (numerical) ratio than 3.42 in that carrier because the smaller the number, the larger the pinion gear, which requires the ring gear to move further away. This is why there are different carriers. Also, since most people want to go the other way, you can buy thick aftermarket gears for higher (numerical) ratios, but not gears for the lower ratios. And of course, this is a Type O axle, so new gearsets are almost nonexistent.
More importantly, a Type O with 3.91 gears is worth more intact. You'd be better off both selection-wise and financially to swap the complete axle for a Corporate ten bolt. Don't be fooled by the 12 bolts on the cover of your Type O, it only has an 8.5", ten bolt ring gear.
"You can't physically put a lower (numerical) ratio than 3.42 in that carrier because the smaller the number, the larger the , which requires the ring gear....."
The other day I noticed that CO.com would NOT let me enter a certain phrase. I appeared when I typed it, but when submitted it was absent. Nothing naughty either. like above. Correcting it had no effect.
more site issues.
more site issues.
more site issues.
more site issues.
Apparently the problem is you, Chris...
gevosrears
June 8th, 2015 05:56 AM
oldspackrat
October 7th, 2014 05:15 PM
70442rag
Drivetrain/Differentials
September 30th, 2013 08:02 PM
