10 bolt 7.5 questions
Hey Guys,
Being new to this site and 10 bolt rear ends I've got a few questions.
I've got a rat rod with the 10 bolt under her with 28" tall tires. I did the chalk mark test to find out the gear ratio. With only one tire off the ground...wasn't sure if that mattered or not.
I turned the drive shaft 2 times and the tire turned 1.7 turns. So if my math is right I divided 1by 1.7=.588 x 4= 2.35 that's with 28" tall tires.
So I'm guessing I really have 2.73 gears? If this helps any while I'm going 70mph I'm showing 2K on the tach. This is with a 400 tranny.
I'd like to get a different gear in her and I thought a 3.23 gear would be a better gear and still be good on the highway. I don't think 3.08 would be a big change, the 3.23 just seems better.
I looked in Summit and came across this lower carrier or higher carrier stuff which I figured meant 2 series or 3 series. Am I on the right track with this?
I was going to get a Richmond gear but they don't make the 3.23 2 series gear anymore.
Yukon still does but it's pricey, is Yukon any good?
10 bolt 7.5 2 series 3 series deal
Ok 7.5 carrier breaks are as follows
2.14-3.08 2 series
3.23-4.56 3 series
Yes Yukon gears are good and Richmond is NOT Richmond gear anymore they are now Motive Gear with a Richmond badge.
I can see what I get Yukon gears for as I am a seller for them.
Since yoru carrier is an open it would be cheaper to get a 3 series carrier I have plenty here if you need. YOU just need to know the axle spline count as 1975-1988 were 26 spline 7.5 rears and 1990 -2004 were 28 spline 7 5/8 7.6 rears.... They all really are 7.5 rears when you go to buy gears though.
3.23 3 series will be cheaper to find and maybe you could even find used. I here 3.23 was popular in the mini astro vans back in the day...
Jim Mitschke
JD
2.14-3.08 2 series
3.23-4.56 3 series
Jim Mitschke
JD
Monzaz,
If I'm understanding you right...when you talk about carrier you mean the internal guts right? So the carriers are interchangable within the housing?
All I know so far is my rearend came out of a 80's Cutlass so I'm guessing it would have the 26 spline axles.
Can you give me a price on new Yukon 3:23 gears for a 3 series carrier. Along with a new 3 series carrier.
Question: how do I tell if I have a limited slip or not? If I jack up the ride with both wheels off the ground then what?
72442conv
March 19th, 2012 07:14 AM
