a couple of questiions
Old July 31st, 2015, 05:30 PM
MBrown's Avatar
redoing the interior of my 1971 Cutlass fastback. the a-pillar trim was off when i got the car, does the dash pad have to come off to install these? and at the bottom of the back window, is there a trim piece that screws on there, over the package tray?
Thanks,
Mark
MBrown is offline
Old July 31st, 2015, 06:09 PM
2blu442's Avatar
Hi Mark
No, you don't have to remove the dash pad to install the A-pillar trim pieces.
Then yes, there is a plastic trim piece at each lower inside corner of the back windshield. Its common for these to be brittle and break when being removed. I'm pretty sure they're reproduced, you might check with Fusick.com
John
2blu442 is offline
Old August 1st, 2015, 05:46 PM
MBrown's Avatar
Thanks, John!
MBrown is offline
Tvan
April 10th, 2012 02:06 PM
74omega
Drivetrain/Differentials
July 7th, 2008 09:46 PM
rocket69
June 15th, 2008 09:12 PM
HAFROD
April 6th, 2008 06:47 PM
Rallye469
March 24th, 2008 09:29 AM
Quick Reply: a couple of questiions
