Help: Radiator hoses
Old Nov 15, 2008 | 09:47 PM
Iragh's Avatar
im looking for a molded lower radiator hose for a 1964 cutlass with a 330 so far every thing ive looked at says they have stopped production on this item if anyone can help id even buy a NOS hose. also i neeed the bypass hose im having trouble finding that as well
Old Nov 16, 2008 | 05:33 AM
dynamic88's Avatar
have you tried your local parts store? i was able to get mine for a 65 olds. they had to order it, but i was able to get them. if not try hemmings motor news. there is always someone in there. or year one, they specialize in the cutlass, usa parts, fusicks etc. chris
Old Nov 16, 2008 | 07:04 AM
You should also look at YearOne, Kanter, and Fusicks.
Old Nov 16, 2008 | 07:43 AM
Unfortunately the 64 330 motors used the one-year-only water pump with the outlet on the driver's side.
Old Nov 16, 2008 | 08:30 AM
Bluevista's Avatar
Registered
http://www.autohobbydigest.com/64olds.html
They say the molded hose is no longer available.
Allan
Old Nov 17, 2008 | 01:19 PM
Iragh's Avatar
thanks for the info i put out feelers to the couple of sites you guys suggested does anybody know of another vehicle that has the outlet on the drivers side that i might be able to cut down and make work? thanks for the help it is greatly appreciated
Old Nov 17, 2008 | 03:41 PM
kaz442's Avatar
rockauto.com says they have it gates #26504 $12.85 hope this helps. JKaz
belairbob
Dec 24, 2011 06:47 PM
64oldsguy
Apr 17, 2011 03:31 PM
ROCKET VAPOR
May 7, 2010 06:41 AM
squirell
Aug 25, 2009 09:21 AM
65cutty
Jun 12, 2009 06:45 AM
