350 to a 442
Old Oct 2, 2008 | 02:13 PM
Sully69's Avatar
350 to a 442
I have a 69 Olds Cutlass Supreme. I'm about to go through it. The question I have is "Can I convert it to a 442"? Would that be a bad thing to do if I could.
Old Oct 2, 2008 | 06:00 PM
kevdog442's Avatar
Member
With enough cash its possible to make it look like one, but the Supreme would be a bit more difficult than a regular Cutlass or F-85 due to the different side moldings.
Old Oct 2, 2008 | 06:47 PM
csstrux's Avatar
Any thing is possible, just don't try to pass it off as one when it comes time to sell it.
Old Oct 3, 2008 | 08:43 AM
A real 69 442 would have a different VIN, but you can turn it into a clone. Virtually all of the necessary cosmetic parts (grilles, emblems) are available from repro houses. The cutout back bumper is not. You'd also need to change the drivetrain and suspension.
Old Oct 3, 2008 | 08:45 AM
Actually, now that I think about it, did the 69 Supreme 2dr use the flat hood or the "double hump" hood? If the former, you'd need to find the correct 442/Cutlass S hood as well.
Old Oct 3, 2008 | 09:04 AM
88 coupe's Avatar
Junior Member
........ Would that be a bad thing to do ........
Depends whether your intent is to please yourself, or everyone else.
There is no "bad way" to do the former, and it is impossible to do the latter.
If you chose to use a Chev engine, it would only be "bad" if you talked about it on an Olds site.
Norm
Old Oct 3, 2008 | 11:53 AM
You could easily convert it into a 442. However, it would be difficult; if not near impossible, to turn it into a 98. Those were the best Oldsmobiles available.
falconsfan
May 14, 2015 05:47 AM
dharlett
Sep 23, 2009 03:30 PM
Jokers69
Oct 5, 2006 03:00 AM
<Eddie>
Nov 1, 2005 07:30 PM
