HP Ratings....pre 1971 vs. 1971 and up??
Old October 26th, 2011, 07:12 PM
79MKII's Avatar
I have always found the HP ratings for the 68-72 Cutlass 350's to be confusing. For example, my 72 supreme was officially rated at 180 HP with a 4bbl and dual exhaust. Can this be correct? That's a really small number compared to the 1970, for example, which IIRC is over 300. Were there actually that many changes made or was it just how they rated the HP for insurance purposes?
Now that I've sold my '72, I'm wondering if it's worth sticking with the '68-'70 cars instead of the '68-'72 range that I've been looking at.
Is there much data out there on the actual HP numbers for the stock 350's?
79MKII is offline
Old October 26th, 2011, 07:17 PM
jaunty75's Avatar
Around that time, the auto manufacturers went to (or were required to) post "net" horsepower ratings instead of "gross" horsepower. I don't know all the ins and outs and all the correct terms, but originally they would report the hp when there was no load on the engine. Net horsepower means what's left to actually move the car after the power drain for running the various components (power steering, alternator, A/C, etc.) was subtracted.
Like I said, I may not have this all completely correct, but it was something like this, and I'm sure others will have a better answer.
jaunty75 is offline
Old October 26th, 2011, 07:25 PM
1974 DELTA 88
AZ455's Avatar
This is a pretty good read on the subject...
http://ateupwithmotor.com/automotive...orsepower.html
AZ455 is offline
Old October 26th, 2011, 08:39 PM
Aceshigh's Avatar
1971 and earlier = GROSS horsepower rated.
1972 and later = NET horsepower rated.
So yes, anything before 1972 had a rating that's weaker by today's standards.
So for example a 1964 GTO which was the first car of the Muscle Car genre had
claims of 325hp. The reality was after 1972 that 325hp became more like 280hp.
GROSS HP
Engines were rated by what a stripped engine put out in perfect conditions on
a stand with no accessories. This is also how today's crate engines are rated.
Very misleading too, buyers get upset when they don't dyno out that high after install.
NET HP
was rated by what an engine put out in the engine bay fully accessorized.
That's why the HP ratings dropped in 1972. Then the emissions choked them after.
Aceshigh is offline
Old October 26th, 2011, 09:52 PM
72 cutlass455's Avatar
To add to the soup GM had a 10-1 policy 10 lbs for 1 hp there for a 3500 lb car would be rated at 350 hp regardless of the true hp but would make at least 350 hp.
72 cutlass455 is offline
Old October 26th, 2011, 11:25 PM
1974 DELTA 88
AZ455's Avatar
If that's true my Delta must make some crazy power..
AZ455 is offline
Old October 27th, 2011, 03:08 AM
Aceshigh's Avatar
LOL.....that's a new rumor I've never heard before myself.
Aceshigh is offline
Old October 27th, 2011, 05:05 AM
79MKII's Avatar
Weren't there at least some real changes made though on the 71 and 72 vs. the 68, 69 and 70, for example? The valve seats and maybe lower compression? Or will a 1971 350ci dyno the same as a 1970 350ci (with all other factors equal) in the real world?
79MKII is offline
Old October 27th, 2011, 08:28 AM
79MKII's Avatar
Great article, thanks.
79MKII is offline
Old October 27th, 2011, 09:34 AM
455man's Avatar
Yes the compression was lower starting in 71 or 72 which lowered horsepower also.
455man is offline
Old October 27th, 2011, 09:51 AM
GM Enthusiast
OLD SKL 69's Avatar
The compression was lowered in 71 Olds engines, a year before Chevrolet did it to theirs. That, and the change to net hp ratings from gross, and the new emissions equipment (egr valve, catalytic converter, smog pump) really made the 70's engines look and feel anemic compared to their 60's counterparts.
OLD SKL 69 is offline
Old October 28th, 2011, 06:01 PM
79MKII's Avatar
I drove a beautiful '71 Cutlass Supreme today. It's a very nice car and ran great but wow was it a dog! Seemed even slower than my '72, so that was pretty disappointing. Didn't have the passing gear working properly so that didn't help.
I can't help but wonder what a 1970 would feel like....I remember my friend's '70 being way faster than my '72 but I'm not sure if his engine was stock or not. Anybody driven both recently?
79MKII is offline
Old October 28th, 2011, 07:05 PM
I had a high-comp 4bbl '70 350 years ago, with about 100,000 on it.
Ran like a raped ape.
MDchanic is offline
Old October 29th, 2011, 07:43 AM
GM Enthusiast
OLD SKL 69's Avatar
The car you drove probably needs to be checked over, and yes the kickdown cable would make a big difference in driveability.
My 71 is all stock, 350, 4bbl. I rejetted/changed metering rods in the carb until I came up with the right combo for today's gas and put dual exhaust on it with flowmasters. It is not a race car and I'm not going to beat a new Camaro, but I can easily do a 20" burnout with a 2.56 rear and it pulls strong throughout the rpm range.
Old October 29th, 2011, 08:40 AM
vette442's Avatar
The 1971 and 1972 engines are virtually identical - the different numbers are simply from the gross to net rating method change. A 1971 Supreme's 265 gross hp is the same output as 1972's 200 net ('M' code with 4 barrel and dual exhaust). The 68-70 cars with high compression definitely are definitely stronger - you'll notice a difference. I have two '72 455s and a '70 455 and I can tell a difference in response. Same with the 350s - my '68 high compression 350 was stronger than the several '72 350s that I've had.
Terry
vette442 is offline
Old October 29th, 2011, 11:41 AM
79MKII's Avatar
I guess if I get this '71 I could hop it up a little bit with mild mods but maybe I should wait for the right 68-70 car.....unless a really good deal comes along.
I just looked at a 71 442 today and it has a '76 455 in it. The car looks nice but I couldn't drive it as it has no exhaust. I would guess the 455, even though newer, would have more power than a 71 or 72 350 right? I've never owned a big block....just 350's and 260's (and a 4 door 6-cylinder but I won't count that!)
79MKII is offline
Old November 1st, 2011, 11:05 AM
Seff's Avatar
As far as I could read on the Olds FAQ, they dished the pistons deeper in '71 and until '73 or so, where they made larger chambers in the heads instead. This would mean that if you take heads off a '72 or older 455 and put them on your '76 455, you'll have high-compression pistons and small chambers, giving you good compression. I don't know if this is only true for 350 CIDs or for both 350 CIDs AND 455 CIDs.
Originally Posted by Olds FAQ
From what I've seen, it appears that in '71 (when they needed to drop all of the compressions in GM cars - 10.5 to 8.5) that their first method of doing it was to dish the pistons more. In 1973 they increased the chamber sizes on the heads and went back to piston comparable to 1970 and prior.
Seff is offline
Old November 1st, 2011, 11:33 AM
79MKII's Avatar
That's interesting stuff about the heads....sounds like it could work.
I'm leaning toward the '71 Supreme with the stock 350. It's a really nice car and I could always throw on a few engine upgrades if I wanted to. I'm sure there are lots of good articles on here about that.
I guess I had just hoped that the '71 would seem a little faster than my '72 but it sure doesn't. The engine is probably identical to the one I had in my '72.
79MKII is offline
Old November 1st, 2011, 11:52 AM
Seff's Avatar
Apart from the '71 having 7 heads instead of 7a heads, they should be practically identical. Putting high compression pistons it in would get you a long way towards that pre-'71 performance, it would seen. I'm not sure, though.
Seff is offline
Old November 1st, 2011, 12:38 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
If you don't plan to put new pistons in,
1971 and 1972 350 were the worst. You would be better off getting any other year in my opinion.
71 & 72 are the most popular cars on here that people want to "fix up" and they are the biggest dogs of them all as far as engine piston compression goes.
J-(Chicago) is offline
Old November 1st, 2011, 01:47 PM
79MKII's Avatar
You know, I always thought my '74 was much faster than my '72.
79MKII is offline
Old November 2nd, 2011, 03:18 PM
BlackGold's Avatar
Any '71 or '72 Olds 350 that behaves like a dog -- even if a 2 bbl -- has got something wrong with it. That's not how they came from the factory.
I drove a '72 2-bbl 350 Cutlass S for years. Even with its highway gears, it was a lot of fun to drive, would burn rubber until you lifted, and would never be called a dog.
BlackGold is offline
Old November 2nd, 2011, 03:33 PM
Where were you in '72?
boondocker's Avatar
I installed flat tops and opened up my Qjet on my '72 350 and now the only big issue i'm having now is getting all the new found torque to the ground. I swear when I hit the pedal this thing sublimates tires.
boondocker is offline
Old November 2nd, 2011, 03:37 PM
Seff's Avatar
Looking forward to seeing what kind of a difference high comp pistons will make for my 72 350 as well.
Seff is offline
Old November 2nd, 2011, 07:44 PM
79MKII's Avatar
The engine in the '71 ran perfectly. Really smooth, no smoke or noises, not even a lifter tick. It just barely moved when it was floored. Here are a few pictures I took with my cell phone....this thing isn't a 260 in disguise or something is it?
79MKII is offline
Old November 3rd, 2011, 08:51 AM
455man's Avatar
I'd heard about 4% increase in horsepower for 1 point of compression increase. So I would not expect a lot of horsepower. I think the exhaust is the best place to gain some horsepower unless you are planning to rebuild the motor.
And I'll agree my 72 350 2bbl still impresses me after driving around a 200hp v6.
455man is offline
Old November 3rd, 2011, 09:18 AM
Seff's Avatar
I already have some kind of fancy exhaust, so we'll see how far that takes me.
Seff is offline
Old November 3rd, 2011, 12:47 PM
boondocker's Avatar
It's all about the combination, increased compression, more fuel, more air, more exhaust. I took a stock '72 2bbl 350 and applied the above principals and i'm very impressed with the results, a much more responsive engine...stock non-posi rear end with a Transgo mild shift kit. I don't know what the dyno results are in terms of percentages...my butt dyno tells me this was well worth the effort.
Old November 3rd, 2011, 12:55 PM
Seff's Avatar
Got a cam with more low-end torque, high comp pistons, some form of newer exhaust, and it's a 4-barrel with a good Q-jet on it. I'll be more than happy, I imagine.
Seff is offline
Old November 3rd, 2011, 01:06 PM
boondocker's Avatar
If I were state side I would scoop that one up real quick, looks immaculate, suspect the rest of the car is the same...what I would do is pull that engine and set it up right, although a good tune up and carb kit might be an option.
Old November 3rd, 2011, 04:08 PM
  #31
79MKII's Avatar
It truly is a very nice car. The way it rode and drove was awesome too....so solid it was surprising. So many times I look at cars in person and they're not nearly as nice as they're made out to be, but this one is. I'm still thinking long and hard about it....
79MKII is offline
Old November 3rd, 2011, 04:34 PM
  #32
That truly is a pretty car. Scoop it up.
We can always scrounge you together some go fast parts once your cash recoups.
We'll kick the dog out of the dog house.
Old November 8th, 2011, 06:51 AM
  #33
79MKII's Avatar
OK, here's another HP question. There's another '71 Supreme listed locally here that claims to have a 275 HP 350, factory option code L74. Didn't make that much HP in 1971, right? I think the L74 in the earlier years had higher HP but it was just the std 350 4 barrel for '71, wasn't it?
L74 Engine, V-8 4BC (330)
L74 High Compression V-8 Engine (1966)
L74 High Compression V-8 Engine 4-Bbl. (1967)
L74 High Compression 350 Cu. In. V-8 4Bbl. (1968-1970)
L74 350 Cu. In. V-8 4 Bbl. (1971)
L74 455 Cu. In. 4-Bbl. (B Body) (1972)
79MKII is offline
Old November 8th, 2011, 07:10 AM
  #34
1974 DELTA 88
AZ455's Avatar
Here are the HP/Torque ratings as well as changes in compression ratio from 1968 through 1974 for Olds V8s.
1968 - 1973:
1974:
AZ455 is offline
Old November 8th, 2011, 07:34 AM
  #35
vette442's Avatar
Misinformed seller. You're correct, it was the base Supreme engine with 260 gross hp / ~200 net hp in 1971.
vette442 is offline
Old November 8th, 2011, 09:59 AM
  #36
79MKII's Avatar
[QUOTE=AZ455;338990]Here are the HP/Torque ratings as well as changes in compression ratio from 1968 through 1974 for Olds V8s.
QUOTE]
That's great info...comp ratios and everything. Really explains a lot, thanks for sharing.
79MKII is offline
Old November 8th, 2011, 01:42 PM
  #37
1974 DELTA 88
AZ455's Avatar
No problem. I been meaning to look that up since I saw this thread, but things come up and I forgot all about it.
Kind of interesting to see the differences. The 1974 chart is a little strange, as it shows HP and torque at several different RPM.
On the page that shows 68 through 73 you will also notice that it is only NET horsepower 1972 and later, and from there the numbers take a huge dive. So I would imagine anything after 1971 would have comparable power to what the 1971 specs are using the gross hp rating system, since in 1971 the compression ratio was already 8.5-1. Then there is emissions to take into consideration. . .
AZ455 is offline
Old November 8th, 2011, 10:57 PM
  #38
Aceshigh's Avatar
I put my 1970's rebuilt 350 on a dyno and it spit out ~300hp at the crank and ~425ft lbs.
That's the ONLY way to really know what you have, to put it on a dyno.
Whatever your choice is, you need to get the best flowing head you can for it.
Mid to late 70's isn't going to be the best options at all.
That's where you make your power. Olds heads need ALOT of work in many cases.
Aceshigh is offline
Old November 9th, 2011, 03:55 AM
  #39
bkeese's Avatar
I don't know about Gross vs Net HP, but I do know about high compression vs low compression. 71 was the beginning of the demise of the muscle car and the EPA had alot to do with it. Why isn't there a 71 W31? Olds tried but it couldn't pass emissions so it died. Beginning in 71 the emissions were measured by emissions emitted / volume of gas consumed. So the wigs in Detroit decided it was easier to consume more gas so they could emit more emissions. They retarded the timing and lowered the compression, thus consuming more fuel and past emissions. Detroit figured that the consumer didn't have a choice except to buy what it offered. Then the 73 oil embargo hit and muscle cars couldn't be given away. In 74-75 my best friend sold his k-code 65 Mustang convertible in great shape for $200. It was the only offer he had. This death spiral continued for over a decade giving the Jap cars a huge boost in sales and market share until Detroit decided to engineer efficient cars which again produced performance. Thank God!
As to manufacture rated HP, it was all marketing. The 1969 Z28 Camaro is rated @ 290 hp. GM also had a ceiling of 400 cid on all mid sized cars except the Corvette until 1970, but ingenius dealers figured out how to beat this using COPO (Central Office Production Order), hence the Yenko and Baldwin-Motion Camaros. COPO was designed to produce green vans for the phone company.
So, 1970 was the first year of the over 400 cid and the last year of high compression. It was a very good year!!!!!!!!!
So to answer your question is there a difference between 1968-1970 and 1971-72?
Hell yea!!!!!!
bkeese is offline
Old November 9th, 2011, 04:12 AM
  #40
Originally Posted by bkeese
... the wigs in Detroit decided it was easier to consume more gas so they could emit more emissions. They retarded the timing and lowered the compression, thus consuming more fuel and past emissions.
No, compression was reduced and timing retarded to reduce oxides of nitrogen, which were regulated by the new environmental rules.
From "Numerical Prediction of NOX in the Exhaust of a Compression Ignition Engine,"
by A. A. Pawar, and R. R. Kulkarni, in World Academy of Science, Engineering and Technology, 43, 2008:
"... NOx emissions are related to start of combustion timing and the energy released in premixed burning. Earlier start of combustion causes higher cylinder pressure and higher combustion temperature, which cause higher NOx emissions. More energy released in premixed combustion causes more rapid cylinder pressure rise and higher combustion temperatures that consequently elevate NOx emissions."
This article refers to diesels, but the formation of NOx is the same in both.
MDchanic is offline
Quick Reply: HP Ratings....pre 1971 vs. 1971 and up??
