Neutral Satey Switch question
My 72 cutlass's back up lights dont work.....The car will start in any gear which makes the neutral backup safety switch suspect.Now I brought a new one but before I install it Im trying to understands exactly how they work.......When I shift my floor shift th350 shouldnt the steering column rotate the little thing on the neutral saftey back up switch....I ask because earlier when I was under the dash and I shifted through the gears with the car off....I didnt see anything move on the neutral saftey switch.Am I misunderstanding something?
Wow!Thanks man!I do have headers so maybe thats why they did it........I wish there were something I could do to keep the headers and still run the back drive linkage
You can make a switch to work on the floor shifter if there is no way to clear the headers. It might take some minor engineering, but it's doable.
Depending on the specific headers, you can often get the backdrive linkage to fit with some minor bending. Failing that, there are aftermarket cables for street rods that run from the steering column to the trans.
I had no interference between the headers and the backdrive linkage on either my 70 Supreme or the 71 convertible. Both 350 cars with Heddman headers.
Charly9g
November 6th, 2016 05:10 PM
oldspackrat
November 17th, 2014 06:31 AM
