OAI air assembly
Old October 19th, 2009, 05:02 AM
Wasted's Avatar
OAI air assembly
Well I just got a OAI hood for my 70 SX and I was looking at ways to seal the air cleaner to the hood. So I was wondering it I could get the OAI Air Cleaner Assembly for Thornton http://gawain.membrane.com/~thornton/aircleaner.html and put it on my original 2bbl air cleaner base? I assume I can but before I go and spend $430 I wanna make sure. Thanks in Advance.
Wasted is offline
Old October 19th, 2009, 08:32 AM
Wasted's Avatar
Alright I just got off the phone with thornton, turns out the 2bbl cleaner base is about a inch smaller.... Now all I have to do is figure out how to get a clean install with out switching the original crab and intake...
Wasted is offline
Old October 19th, 2009, 12:17 PM
svnt442's Avatar
They never added the W25 hood to the 2 bbl carb'd engines. Why don't you want to get a 4bbl for it?
svnt442 is offline
Old October 19th, 2009, 01:26 PM
Wasted's Avatar
I know they didn't, Im just trying to keep this car as original as I can, except for the w-25 hood which Im trying to make it as easy as possible to switch back to stock. Plus since this isn't a daily driver. I know if I start to switch the intake and carb Ill get a bad case of might as well do it while its down. If that happens then I know my plan of keeping it stock will go out the window. Then I wont have a old car to drive for a little bit since my other 2 aren't up to par yet.
I know it probably sounds dumb to some but I already have to many projects planned and I just wanna be able to jump in the car and go for a nice cruise.
Wasted is offline
Old October 19th, 2009, 01:53 PM
svnt442's Avatar
Well to be fair they did put a 4bbl on the SX mid year . You could find a cast intake and a quad and have fun with it.
Besides...the sound of those secondaries opening coming thought the hood is AWESOME!!
svnt442 is offline
Old October 19th, 2009, 07:01 PM
While I agree that a Qjet is the way to go, you can buy adapters to put a 4bbl air cleaner on your 2bbl carb. Check Summit or Jegs.
joe_padavano is offline
Old October 20th, 2009, 10:52 PM
Wasted's Avatar
Alright well I decided to get the adapter for now. The adapter will only stay on there until I can find a intake and a carb to rebuild. Hopefully by then I will have the 64 registered so I wont have to go without a Olds for a little bit.
Wasted is offline
Don Roberto
August 12th, 2019 10:31 AM
WTony
November 15th, 2013 04:57 PM
virtualwsp
July 17th, 2013 07:33 PM
69442
May 10th, 2013 04:35 PM
WTony
July 3rd, 2010 11:12 AM
Quick Reply: OAI air assembly
