*** No Brake Lights??? Please Help
Old June 11th, 2006, 03:55 PM
Pete77's Avatar
I am currently working on my 1972 Cutlass trying to do everything before I get it on the road. I have no brakes lights. I changed the stop light switch and still nothing. My lights work regularly just do not flash when I apply the brakes. Any ideas would be great I don't want to get rearended. thanks alot
Pete77 is offline
Old June 11th, 2006, 04:07 PM
Tom Servo's Stunt Double
texasred's Avatar
Double posting is frowned upon. Check the Electrical section for a reply.
C.J.
texasred is offline
Old November 20th, 2006, 10:45 AM
monsterpuff's Avatar
there is a switch under the brake pedal it might be sticking.the part is cheap and easy to replace
monsterpuff is offline
Old February 15th, 2007, 02:07 AM
Jim's rare 80
Jim's rare 80's Avatar
Hi. There is a harness in the trunk. Double check those connections. IF that doesn't fix it, check the harness that runs under the carpet, next to the door. Hope this helps. Jim.
Jim's rare 80 is offline
907delta88
April 11th, 2014 12:33 AM
tds
May 7th, 2013 10:18 AM
65droptop442
May 5th, 2013 12:21 PM
Del70
August 2nd, 2011 04:40 PM
Sid
September 10th, 2010 02:33 AM
Quick Reply: *** No Brake Lights??? Please Help
