I need some help!
I need some help!
I have a 72 cutlass supreme. I think that I will need new floorpans, I can afford the pans. But I dont think I can afford to have someone to put them on. How much does it cost to have someone put them on for you? I do not know how to weld, would it be hard for someone to weld in floorpans for their first time? I have never realy done anything car wise(i got the car to learn on) so what should I do?
There is a really good step by step procedure with pictures on a chevelle site which are A bodies also. Not to challenging provided you have good tools. I only needed patches but went with full floor and trunk replacement. Glad I did. Get the metal from Goodmark they fit perfect. Do it in baby steps as some of it can be frustrating. The better you cleanup your old floors the better you can locate your spotwelds and the more spotwelds you drill out the easier the floors come out of the rockers and you wont beatup your crossmembers. Find the post. I just googled it and found it. It is an older guy with alot of photos and captions.
marxjunk
September 24th, 2014 03:20 AM
pontchief
20
May 8th, 2007 05:06 PM
MB3110
August 20th, 2006 04:41 PM
