Dual exhaust question
Hello all,
I've got a question about dual exhausts. My '76 came with a single exhaust like most did. I would like to put dual exhausts on it. Upon looking underneath the car, I saw that the transmission shift linkages are right in line with where a left exhaust pipe would traditionally go. I know there are double hump crossmembers on the earlier cars, but I'd like to avoid replacing that if possible. Could I run the pipes closer to the outer edges of the frame? How have you guys run your pipes?
I was afraid of that. I don't have a lift or even a transmission jack to hold up the trans. while I swap out crossmembers. I'm working out of my garage, so I don't have access to a lot of air tools.
Are the crossmembers bolted in or riveted in? I think on my pickups they're riveted in.
I was hoping I'd be able to run the exhaust pipes along the frame rails, but maybe that's not advised.
All you need is a normal floor jack and a short piece of 2x4. You're not removing the trans, just lifting the back of it enough to take the weight off the crossmember. The crossmember is bolted in - it has to come out to remove the trans. And you should plan on running the pipes exactly where the factory did on the 1973-74 dual exhaust cars, which is not along the frame rails. Don't overthink this. GM did all the engineering for this almost half a century ago.
If you are taking the car to a exhaust shop for a factory type dual exhaust, (which is what I would do also), why not just get a dual hump crossover and ask them to install the crossmember while they are bending/installing the dual system?
That is a good suggestion Greg. They will have it on a lift and it will be easy for them to do. It will save you a ton of frustration. It might be a good time to change the transmission mount.
G-force sells dual-hump crossmember for your car, and Summit aswell. Atleast on some point the Summit crossmember was actually G-force, just cheaper. Go figure.
You need to enlargen the bolt-holes at frame a bit, but otherwise its a bolt-on deal. And its not touching shift-linkages / anything if factory-routed. That is, if you cant locate factory dual-hump crossmember, or dont want to fabricate your own.
