Chevy 350 SB boltin up to tranny
Old September 11th, 2006, 08:38 PM
t_visker's Avatar
I have a chance to get a rebuilt chevy 350 SB for 350 bux!!! I have the 87 cutlass supreme brougham.. nott sure what transmission.. but would this bolt up to it.. the tranny has OD.. and its an auto..
t_visker is offline
Old September 12th, 2006, 04:48 AM
Past Administrator
Oldsguy's Avatar
No, wrong bolt pattern on the bell housing.
Oldsguy is offline
Old September 12th, 2006, 05:45 AM
t_visker's Avatar
bell housing
couldn't I just change the bell housing??
t_visker is offline
Old September 12th, 2006, 07:29 AM
orange442's Avatar
Swap?
If it is a 200-4R OD it should have the dual bolt pattern and will bilt up to the Chevy engine. You will have to change frame mounts and engine mounts or it will not bolt up to the frame. You will also have to get all of the accessories and brackets with the Chevy because none of the Olds stuff will bolt up to the Chevy. If you can find a Olds 350 or 403 it would be a better route to go because it would be a direct bolt in. Might vsave you a lot of hassle and money sticking with the Olds motors.
orange442 is offline
Old September 12th, 2006, 07:47 AM
Tom Servo's Stunt Double
texasred's Avatar
Plus the starter is on the wrong side as is the alternator and A/C. Figure a lot of splicing and new A/C lines (if you are going to use it).
Go with the SBO.
C.J.
texasred is offline
moys71
February 16th, 2021 08:22 PM
TOONLOVESCHERYL
February 4th, 2016 06:30 AM
69OLDSCUTCONV
February 1st, 2011 06:09 AM
gscott819
July 28th, 2009 07:02 PM
Quick Reply: Chevy 350 SB boltin up to tranny
