BFG T/A Tire Pressures
Old August 1st, 2018, 09:02 AM
brown7373's Avatar
Anyone have a good guide for tire pressure on new BFG Radial T/A 225 70R14? I'm looking for all around regular driving, no competition. Obviously the original sticker pressure was for bias ply.
brown7373 is offline
Old August 1st, 2018, 09:08 AM
442Harv's Avatar
Your tires should have that info on them, look close, side wall.
442Harv is offline
Old August 1st, 2018, 10:07 AM
The tires will have the maximum pressure for the maximum load on them, but that doesn't translate to what to run for regular use.
35 PSI is what I run on my 245-60-15 BFG TAs. This gives even tread wear and doesn't seem to make the tires too hard and give a rough ride. If you feel the ride is rough, lower the pressure.
This is what I do on my Jeep. The 33x12.50 tires on it show maximum pressure of 55 PSI, but the Jeep is so light that would feel like driving down a railroad track. I run them at 26-28 PSI on the road and that gives an even contact patch and a smooth ride.
Fun71 is offline
Old August 1st, 2018, 10:36 AM
My442's Avatar
I find 30 PSI works well with T/A tires.
My442 is offline
Old August 1st, 2018, 11:07 AM
28-32 usually works well on T/A's. I run mine at 30 also.
oldcutlass is online now
Old August 1st, 2018, 11:10 AM
vette442's Avatar
Ive had 225/70/14 T/As on a number of my cars since 1990 (and three right now). 32 is what I typically keep them at.
Terry
vette442 is offline
Old August 1st, 2018, 11:11 AM
My442's Avatar
It also depends on your shocks.
I run Bilstein, which are typically stiffer than other gas shocks/
My442 is offline
Old August 1st, 2018, 11:22 AM
Dave26's Avatar
I run 32# in my twin to yours. Same size 14’s
Dave26 is offline
Old August 1st, 2018, 02:04 PM
brown7373's Avatar
Sounds like 30 +- is the consensus. The tire shop that sold and rotates them seems to put 33-35 in them, which I think is too much and makes for a harsher ride. And I don't much trust them. They are experts at destroying lug nuts, and use the impact gun regardless if I ask them not to.
Old August 1st, 2018, 02:08 PM
brown7373's Avatar
I know what you mean fun71 about max pressure. I have an old 3/4 ton Suburban. Those big 16 inch tires recommend 80 psi rear and 55 psi front when towing a heavy load. When you unhook and drive with no trailer, it's like it has concrete tires!
Old August 1st, 2018, 08:13 PM
X2. 35 is what I run in all my T/As as well.
joe_padavano is online now
Old August 2nd, 2018, 03:52 AM
Lansing built
1970cs's Avatar
I set mine at 33 psi. In the spring.
Pat
1970cs is offline
Old August 2nd, 2018, 08:48 AM
brown7373's Avatar
My pressure were 35, (2) 37 and 38. Reduced to 30 psi and the improvement in ride quality was dramatic. Much, much less harsh!
Old August 2nd, 2018, 08:54 AM
JohnnyBs68S's Avatar
I run around 35 PSI in my 245-60-14 BFG T/As. During winter, I pump them up to around 40 PSI to help avoid flat-spotting.
After a bad experience of having my one of my SS1s nearly fall off the car due to un-torqued lug nuts after a visit to a tire shop, I refuse to let them mess w/ my nuts. When tires are needed, I remove the wheels from the car, remove the center caps (and trim rings if it has them) and take the wheels in to the shop to have new tires mounted & balanced. Then I pick them up, take them home, re-install the "dressing" and remount the wheels to the car myself.
JohnnyBs68S is offline
Old August 2nd, 2018, 10:10 AM
brown7373's Avatar
I drove the car to the shop because I also wanted an alignment. But I too removed the trim rings and center caps so they wouldn't be damaged. Then I had to remove each wheel again to reinstall the center caps. 4 Wheels times 2 is a lot of work, just because the tire shops have monkeys with zero supervision and zero commitment to keep the customer's car safe. And they are just as bad with late model cars. I know, I need to find another shop, but I can't find any in my area.
Old August 2nd, 2018, 10:11 AM
I refuse to let men mess with my nuts, too.
Koda is online now
olds89
Ninety-Eight
April 4th, 2019 06:56 PM
70-442-W30
March 18th, 2016 10:14 AM
Al Graaf
September 12th, 2012 08:20 AM
CO53Super88
Wheels and Tires
August 27th, 2012 08:28 PM
Doug69Cutlass
April 6th, 2009 06:54 PM
Quick Reply: BFG T/A Tire Pressures
