'68 vs. '69 instrument panel
Does anyone know if the '68 and '69 plastic instrument panel is the same. Like most, mine was cut around the radio when the previous owner put in a cassette player. Anyone got one for sale?
Mike
Mike
The plastic parts are different between 68 and 69. 68 has the ignition switch in the dash (and thus there is a hole for it), 69 has it on the steering column.
Wait, I just re-read your question. The radio plate is a bolt-in part. If the non-stock cutout is confined to the radio plate, you can just swap that piece, not the whole dash. Note that the radio plate is actually die cast metal in those years, and 68/69 are the same.
Joe,
Actually, you had it right the first time. I was referring to the big plastic piece that is attached to the dash. I believe it encompasses the radio and switches below the gauges. Sounds like its a one year only piece. I'll keep looking for one. Thanks for the reply.
Mike
Mike
Joe,
Mike
Mike
rroth01
December 23rd, 2023 04:35 AM
