66 cutlass convertible steering rag joint
Old April 23rd, 2017, 10:38 AM
mazey's Avatar
Finally got around to doing my wiring, got original fuse box redone from american wiring. Been looking at it all winter and finally got around to getting under the dash. Of course its in 70s and i should have done it in february. Oh well..I took out the steering column to make a little more room and realized the rag joint is probably original. I had car since 87. Went to look at different ones online and mine looks different. The 2 "pins or studs" on mine are different sizes Appproximently 9/32 and 9/16. all the ones ive seen have two same size studs. ill try loading a pic
mazey is offline
Old April 23rd, 2017, 10:39 AM
mazey's Avatar
Im not talking about the bolts.
mazey is offline
Old April 23rd, 2017, 10:40 AM
mazey's Avatar
Car has power steering.And yes, the yoke on the steering column are two different sizes.
mazey is offline
Old April 23rd, 2017, 10:46 AM
mazey's Avatar
this is one i bought a few years ago, thought it was correct. But it has two same size studs
mazey is offline
mazey's Avatar
here is pic
mazey is offline
Old April 23rd, 2017, 11:14 AM
mazey's Avatar
i just put old and new on the steering column, looks like there supposed to be gap around studs? the original one wasnt touching.
mazey is offline
Old April 23rd, 2017, 03:19 PM
66-3X2 442's Avatar
The size of the studs isn't really a big deal. What is a big deal is the ground wire that connects one side of the coupler to the other side. That is what makes the ground for the horn circuit. You can buy a rebuild kit that has a new rubber and new studs.
66-3X2 442 is offline
Old April 23rd, 2017, 04:14 PM
To be honest that one does not look bad.
oldcutlass is offline
Old April 24th, 2017, 06:20 PM
mazey's Avatar
thanks. it doesnt looik that bad but it is original. or at least since 1987. in thge pics in post #6 the pic on left is original, pic on rite is a new one i bought several years ago. (been planning on replacing it awhile). Will there be a problem in the different spacing around the studs? Theres more of a gap in new model. Or is there a different part i should use?
mazey is offline
Old April 24th, 2017, 06:21 PM
mazey's Avatar
About 15 years ago i had one tear apart on another car. i turned the wheels while motor was off(no power steering), and ripped the joint apart. Thats why id rather replace this one while column is already out
mazey is offline
joesw31
September 24th, 2016 07:07 PM
bobfo1
Suspension & Handling
October 3rd, 2012 03:00 PM
MDchanic
May 22nd, 2011 09:21 AM
STLCRZY
April 26th, 2011 11:21 AM
J-(Chicago)
August 22nd, 2009 09:25 PM
Quick Reply: 66 cutlass convertible steering rag joint
