350 olds rocket
Old January 29th, 2008, 02:05 PM
69 Cutlass S hardtop
69sAndrew's Avatar
350 olds rocket
I have a few questions about the 350 beast.
I was wondering what the stock HP was on it. I have read 315 but am not sure. Also I take it that the 350 olds engine is much wider, ie; intake than the chev 350.
I have an edelbrock 1405 and performer intake. I will be installing headers and exhaust. Any guesstimate on how much more I can look at?
Thanks guys,
A
69sAndrew is offline
Old January 29th, 2008, 06:47 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
A guess
It depends what year and heads you have. Could be anywhere from 150-300 I would guess. Most likely toward the lower end of that range after all these years I would also guess.
I can't for sure say how much hp you will add with those mods, but if your exhaust plan has an X pipe in it, I think there will be a noticeable difference in the performance with these 2 mods.
J-(Chicago) is offline
Old January 30th, 2008, 01:39 AM
coopsie442's Avatar
yah i would say around 200 to 300 hp, yah i would say xpipe would be a good choice, i got he headman xpipe with a pair of super 40's flowmaster mufflers on my 72 olds with a rebuilt 350. And also put a holley street advenger 670, and maybe upgrade it with msd wires and coil.
coopsie442 is offline
Old January 30th, 2008, 12:02 PM
Redog's Avatar
I drop a '68 350 Rocket in my 85 Delta 88. It came out of a Delmont 88.
Along with the th 400 tranny, I added a Preformer 7111 Mani, Edelbrock 1806 carb, 180* thermo, Double roller timing chain, etc etc etc, and the car already had a Be Cool raditor, Flowmaster Super 40's with an X pipe exhaust.
The car tips the scales between 4050 and 4070 and runs 15.8 in the 1/4 mile, which puts the numbers at 268 HP at the crank according to the HP= weight, ET calulator.
Stock the motor had 255 HP and 355 ft/lbs
Redog is offline
Old July 21st, 2010, 08:15 PM
Jannebill's Avatar
Hi, why go with the X-PIPE? Just curious? What does it do to make the car perform better?
Jannebill is offline
moys71
February 16th, 2021 08:22 PM
ros6872
December 4th, 2016 01:00 PM
cutlassKing
November 29th, 2010 03:05 PM
esisson
May 22nd, 2008 07:47 PM
<Eddie>
November 1st, 2005 07:30 PM
Quick Reply: 350 olds rocket
