1991 Cutlass Supreme SL; Where to begin...
Old December 3rd, 2014, 11:48 AM
barrms25's Avatar
Just got my car back from the tire shop after blowing one the other day. The guys at the shop told me my lower front right ball joint was bad (thus explaining the clunking noise coming from that wheel well!) After numerous 300 dollar estimates from numerous mechanics, I just went and picked up the part in question for 23 dollars. Unlike other ball joints I've seen, these seem to be bolt on joints? Is that normal? Ultimately, what's the step-by-step on replacing this part?
barrms25 is offline
Old December 3rd, 2014, 04:10 PM
Olds Fever
CRUZN 66's Avatar
Normally the ball joints are riveted in place from the factory on "W" Bodies.... If there are bolts, it is quite possible it has been replaced before, which will only make your job easier... otherwise you will have to chisel out the rivets and replace the new ball joint with nuts and bolts usually provided with the ball joint when it is purchased.....
CRUZN 66 is offline
Old December 4th, 2014, 06:42 AM
Step one is buy a factory service manual. Step two is read the section on suspension. There are over two dozen on ebay right now, with the cheapest having a $9 Buy It Now price.
joe_padavano is offline
1968CutlassSupreme
October 9th, 2013 06:15 AM
Tyler Padgitt
January 7th, 2012 02:41 PM
68Tom
January 12th, 2011 07:40 PM
Robert-T
March 4th, 2010 10:23 PM
skubydobdo
October 25th, 2008 04:58 AM
Quick Reply: 1991 Cutlass Supreme SL; Where to begin...
