1972 Cutlass Hurst Dual Gate Switches?
Old February 28th, 2011, 10:56 AM
oldfarmall's Avatar
Smile 1972 Cutlass Hurst Dual Gate Switches?
Hello-
I am converting a column shift auto tranny to console with the Hurst Dual Gate shifter. Model year of my car is 1972. Is there a switch I need to put on my shifter for reverse and neutral? I know on 1970 models had this, but what did they do for 1972? Also, is there a pointer that is supposed to go under the shift indicator lens on the top plate that moves? Otherwise the light would be shining under the top plate in all gears? Pictures and part numbers would be great if anyone has them. Thanks for the advice in advance!
Jesse
oldfarmall is offline
Old February 28th, 2011, 07:44 PM
2blu442's Avatar
Hi Jesse, I think I missed welcoming you to the site, so Welcome!
I'm pretty sure that in 1971-72 the neutral safety switch was located at the bottom of the column just like the column shift cars. Its been a while since I messed with a console but think there was a plastic strip that moved with the lever to shine the light just on the gear that the car was in. Maybe someone has some pictures they can post of that. John
2blu442 is online now
Old February 28th, 2011, 08:32 PM
Boldsmobile's Avatar
Switch stays on the column. No pointer in the shift plate.
This might help get you started:
https://classicoldsmobile.com/forums...dual-gate.html
Boldsmobile is offline
Old March 1st, 2011, 07:27 AM
Correct. Since the Feds required the shifter to be locked with the ignition switch, even floor shift cars retained the backdrive linkage from the trans to the steering column. Since this linkage was already there, Olds kept a single location (and thus a single wiring configuration) for the neutral safety switch.
joe_padavano is offline
Old January 5th, 2012, 09:06 PM
oddball's Avatar
Sorry to bump an old thread, but does anyone have a picture illustrating the NSS bracket setup? I am adapting in a dual gate and removing the backdrive. Got the NSS and the bracket between the switch and the shifter bracket. That's clearly not enough to connect them. Is there another bracket or link that goes between the NSS and the shifter cable arm?
oddball is offline
Old January 17th, 2012, 07:51 PM
oddball's Avatar
Double bump with a pretty please?
I'm convinced Parts Place sent me the wrong switch, but I still can't fathom how these brackets and the (correct) switch are supposed to go together.
Thanks!
oddball is offline
Old January 17th, 2012, 08:05 PM
oddball's Avatar
Nevermind! Found some good pictures at:
http://www.thegoodoldsdays.com/realoldsmobile.asp
oddball is offline
Old January 17th, 2012, 09:38 PM
svnt442's Avatar
Why are you removing the backdrive? It's a safety thing so you can't start the car in gear or steel it without removing the lock cylinder.
svnt442 is offline
Old January 18th, 2012, 08:17 AM
oddball's Avatar
Hey, it doesn't have to make sense.
I'm not particularly worried about theft, nor the safety aspects of the backdrive although I do recognize them. removing it makes the underhood a little cleaner and simpler. I'm also doing a custom rewire, so using this switch makes what I want to do a little easier. I've also heard it has a tendency to jamb and break, so it'll probably be a poor choice in the end.
oddball is offline
oldfarmall
Hurst/Olds
25
April 27th, 2022 08:39 PM
BeenThere
July 1st, 2015 01:18 PM
BeenThere
February 1st, 2013 08:16 AM
oldfarmall
Hurst/Olds
February 28th, 2011 11:48 AM
Quick Reply: 1972 Cutlass Hurst Dual Gate Switches?
