Rough Ride has lost it's charm.
83 Hurst/Olds here
The ride on my 83 Hurst is rough as hell. Any bump, small pot hole etc you will feel right in your butt and back. Gas shocks on all corners. Is it time to replace the rear shocks/springs? Any suggestions? I've never been in another 83 Hurst but I've been in plenty of similar body style chevys that are like a cloud. Car handles and corners extremely well but if I'm not on laser straight/smooth roads it feels like a 70s pick up.
Thanks for the help,
-Adam, PA
-Adam, PA
22565r15 front, 24560r15 in rear. Car had gas shocks when I bought it, put on air shocks then back to new gas on all corners. Tire pressure is to spec of tire (33psi). I have never touched the springs. The Car sits much lower than any 83 I've ever seen. Doesn't body roll if you take hard turns but if I hit uneven pavement there is noticeable vertical rebound (Back springs worn out?).
Do you know if the front end was ever rebuilt? Poly bushings would make for a rough ride.
Since it rides lower, recon a previous owner put heavyier lowering springs in it?
From the factory, the Hurst used a heavier spring rate, gas shocks, rear sway bar, and thicker front sway bar. I never heard complaints of it being too harsh tho-
My '86 rides very smooth with its std suspension, with the addition of the Hurst sway bar setup.
Tires can make a huge difference in the ride. I found this out when I had my 94 Corvette. I never changed the size but used several different brands over the years. The best ride I ever got was on Continentals. They were not nearly as rough as the Michelins or Goodyears.
There is evidence to support it has been lowered just by looking at it vs. other H/Os I have seen. Most 83/84s I have seen look like monster trucks in comparison. I'm considering replacing the rear springs to see if perhaps they are just worn from 30 years of use. It has a nice stance but this is my daily driver so ride comfort is a factor.
Check for Poly bushings too. If some previous owner lowered the car, he very likely added poly bushings too. That is a great idea if your goal is to stiffen the ride for increased cornering and handling, but at the expense of ride quality. You've already indicated a more comfortable ride for everyday use trumps increased cornering.
If you are going to replace your springs you might as well rebuild the front end. You will notice an improvement in ride quality if you replace the control arm bushings. I suggest going with rubber bushings instead of poly. Of course, your best bet would be to sell your 83 HO and buy a Delta 88 or 98.
usertroy
Dec 13, 2012 08:19 PM
Wyze
Mar 27, 2010 04:25 PM
