steering column
Old February 7th, 2017, 02:18 PM
supmarjo's Avatar
steering column
hi, need help finding the part numbers for the upper steering column....fond a few on chebby sites but sizes don’t match..... 1957 olds has 3/4
ID.
trying to eliminate the up in down play in steering wheel....mine look like this one in pic. (chubby) green wire...
supmarjo is offline
Old February 7th, 2017, 03:47 PM
Yellowstatue's Avatar
If that item is the upper bearing assembly, then the part number is 5660482.
Yellowstatue is offline
Old February 7th, 2017, 04:02 PM
supmarjo's Avatar
thanks Yellowstatue......looked up the part number and fond one on ezbay... can i ask what book you use to find these part numbers for a 1957 olds? thanks
supmarjo is offline
Old February 7th, 2017, 04:23 PM
GM factory parts books #573 1946-57...wasn't very clear so I went to PA-93 which goes to '64 and has better diagrams.
Old February 25th, 2017, 09:27 AM
supmarjo's Avatar
thnks...found one on ebbay w your help....ill look to find the parts book too.
supmarjo is offline
starfire
December 9th, 2021 08:21 PM
shamusj
April 27th, 2021 05:45 AM
317Cutty
June 18th, 2014 10:53 AM
ros6872
March 28th, 2014 09:48 AM
oddball
March 4th, 2014 06:42 AM
Quick Reply: steering column
