rear coil spring removal
Old Dec 27, 2007 | 06:57 PM
cola's Avatar
Hi guys
going to attempt to remove the rear coil springs in my 68 cutlass, any suggestions or tips or pictures?
cola
Old Dec 27, 2007 | 09:17 PM
2blu442's Avatar
Springs
I'm pretty sure last time I did that I supported the frame on jack stands, removed the tires, removed the lower shock mount bolts on each side. Then I rocked the axle housing down on one side, pulled the spring out, then went to the other side and did the same. I don't think I removed the trailing arms or messed with the brake lines. John
Old Dec 28, 2007 | 08:31 AM
John's right, though I don't think I even needed to remove the tires. Once the shocks are disconnected the axle will drop down far enough for the springs to fall out.
Old Dec 28, 2007 | 01:15 PM
kevinkpk's Avatar
Yes, unbolt the shocks ( I used a floor jack) and I jacked the body up till the spring would clear. It's not as difficult as it sounds/seems.
Old Dec 28, 2007 | 05:32 PM
68conv455's Avatar
Don't remove the shocks until you drop the axle as far as possible. You may not need to remove them. Also..... You're going to have the car up high (especially if you don't remove the tires), so please, make sure you have redundant supports under your car. Don't risk getting crushed. Safety first!
Old Dec 28, 2007 | 05:33 PM
68conv455's Avatar
After all. We don't want to damage a perfectly good Cutlass on your chest.
Old Dec 28, 2007 | 07:48 PM
Definitely safety first! Also be careful working around suspension parts when the springs are compressed. If one of those springs pops out when it is partially compressed it won't just fly across the room.
When I was doing the front suspension on my 64 98 I used a floor jack to compress the springs between the control arms when I put everything back together. It was pretty scary hearing the spring pop and creak as I compressed it. I was glad when I got the ball joints bolted to the spindle.
Old Dec 29, 2007 | 06:39 AM
cola's Avatar
rear coils
Hi everyone
Thanks for the quick response. I tracked down a chasis service manual and I think I'll wait for it to come in.
thanks again and happy new year to all
Andy
Old Jan 15, 2008 | 04:47 PM
cola's Avatar
rear coil removal
Hi everyone
thanks for all your help, replaced the rear coil springs last week and everything went excellent. I did however have to remove the passanger side wheel. I had trouble getting the coil around the tail pipe.
Thanks again for everyones help
cola
Old Jun 21, 2011 | 06:09 PM
Thor-HoG's Avatar
Thor HoG
Old thread, new springs :)
Not sure if those on this thread are still around, but I just found it and am about to do the exact same thing on my 72 Cutty. Just wanted to say thanks for the advice!!
Old Jun 28, 2011 | 07:48 PM
Lady72nRob71's Avatar
Old threads can always be good reference material. Lots of them here!!
Old Jun 28, 2011 | 10:01 PM
getawaycar's Avatar
1968 442 restoration
No matter how old the thread... the cars are still older.
Old Aug 4, 2011 | 05:28 PM
sykosoft's Avatar
Not to resurrect, but this method worked great. I purchased Moog Variable Rate Wagon springs for my 1969 4 door Cutlass. It was relatively simple, jack up one side, unbolt the shock, keep going up, remove the old spring, replace with the new spring (needed a bit of leverage to get them in, but no spring compressor), re-bolt the shock, and complete. Confirming that I did need to remove the passenger rear tire, as there is no clearance for removal/reinstallation with the exhaust in the way. That said, the car looks AWESOME, with a very nice 60's rake to it, and this method worked great.
Michael
Old Aug 4, 2011 | 05:36 PM
Only thing that I found helped make the job faster/easier was when removing the shocks I didn't waste time undoing the nut/bolt (unless there's no corrosion and they'll spin off easy). Just overtighten the nut till it busts the end right off the bolt. New bolts and nuts go on soooo much easier. Also a good time to replace the worn rubber shock isolators!
Old Aug 4, 2011 | 06:06 PM
If it is possible (not in every case) that leaving the wheel on gives extra weight to pull the axle down more for easier removal/insertion. Worked for me, but exhaust config is a factor. Also your jack has to get it up high enough. I put mine on 2x8 pieces.
I swapped them without even getting under the car - just working through the wheelwells.
Old Aug 4, 2011 | 06:31 PM
troyh's Avatar
I am about to do this myself also. My 72 supreme has the late 70s butt in the air look that I want to get rid of. I'm going to put sensa trac shocks on also. The front will wait till next year when I can do the control arm bushings. It handles like a pregnant turtle and squeals the front tires around corners even when going slow.
Old Aug 4, 2011 | 06:46 PM
Here's the thread for you then...
https://classicoldsmobile.com/forums...t-end-job.html
Don't let the mightaswell bugs bite!
Old Aug 6, 2011 | 05:57 AM
troyh's Avatar
Last night I tried to take out rear springs. It must have wagon springs in it cause they are over 15 inches long and wont come out! AAARRRGH!! Ill have to get spring compressor monday, busey non automotive weekend planned.
Old Aug 6, 2011 | 07:40 PM
sykosoft's Avatar
I doubt it. My wagon springs only have a 10 inch installed height (about 1.5 inches more than standard). Though, I'm not an expert.
Separate subject, what should I do about my shocks, install longer ones? How long?
Michael
Old Aug 7, 2011 | 03:17 AM
rustyroger's Avatar
'87 Delta 88 Royale
Just a note of cation, make sure the axle doesn't hang up with the E brake cable or rubber brake hoses.
When I put new rear springs in my '83 Cutlass wagon I did the whole job before my girlfriend had made coffee, we started both jobs at the same time.
Doing the fronts was a whole different ball game, took two of us half a day.
Roger.
Old Aug 11, 2011 | 03:05 PM
troyh's Avatar
Mission complete!!! It went great. Springs that came out measured 19 inches! Not sure what they came out of but WOW they are huge. The car sits normal now and rides better too. Cant wait till next year to redo front suspension. Most everything is original 1972 parts.
Old May 14, 2014 | 06:04 PM
MudEye's Avatar
67 Cutlass
Just bought Rear springs for my 67 Supreme. Would these instructions apply?
Body style is totally different. Mine is the longer convertible.
Old May 14, 2014 | 07:55 PM
Yes
Old May 14, 2014 | 08:12 PM
2blu442's Avatar
If its the type O it would be exactly the same, just as Eric said. But I have seen some of the 8.2 rear ends under 1967's. It was a transition year for the rear ends. The 8.2 has something like a big washer bolting the bottom of the spring to the rear end. If yours has that then you'll need to remove the bolt and large washer thingy in addition to the directions here. If that's clear as mud I may be able to come up with a picture for you.
John
71cutlass442
Mar 23, 2022 11:48 AM
Markbgt01
Suspension & Handling
15
Apr 28, 2014 03:45 PM
BStone
Jul 31, 2012 06:17 PM
defiant1
Oct 29, 2010 12:41 PM
Longhorncutlass
Mar 2, 2009 01:53 PM
