Larger wheel studs?
Larger wheel studs?
Ok we are putting new wheels and tires on the wife's car and I noticed how small the wheel studs are. I have heard GM made them larger after 1979 which is what this car is. So could I just drill out the hub and drum on the rear and the brake rotor/hub on the front and put new larger ones in?
The bigger question is, why do you think you need them? A 1/2-20 grade 8 wheel stud has a shear allowable of 14,560 lbs. In the 5 x 5" bolt circle, the five wheel studs can carry over 15,000 ft-lbs of torque per wheel. Can your tires put this to the ground without spinning?
Well the reason I thought it might be a problem is I took off the current Cragar wheels and went to put on a regular wheel and was going to use regular lugnuts and they slid stright over the studs. You could put the nut over the stud and not have them touch each other. I thought that a bit small.
AzChevs
November 8th, 2013 10:33 AM
brokeandugly21
Ninety-Eight
April 23rd, 2011 01:24 PM
