How to get my frame off the body?
Old January 26th, 2010, 10:34 AM
Wilson05's Avatar
So you guys were right. The further I dig into this car the more I want to do to it. Just wanted to start by replacing all the front bushing. Have gotten that far with everything still removed, painted and ready to install. In preparing the frame I just keep digging and digging, find more I want to do. So last night I sat back with a beer in hand and contemplated just removing the body so make it right from ground zero.
So my question is, what am I getting myself into if I do decide to dive in this far? And how do I get the body off? Is it in depth? Right now I have my fenders and all the steering components to include my steering control box removed. I'm thinking its just body mounts(6) and drop the gas tank. Am I about right?
Wilson05 is offline
Old January 26th, 2010, 11:06 AM
Cecil Anderson's Avatar
From someone that does not know anything at all about it--Take more photos than you think you will need, to put all back togeather. I bet someone that really knows will get good info to you. If it is up in the air all the bolts are off the frame will someday fall to the garage floor. Go for it. Post photos --Andy
Cecil Anderson is offline
Old January 26th, 2010, 11:31 AM
https://classicoldsmobile.com/forums...w-project.html
Jamesbo is online now
Old January 26th, 2010, 01:53 PM
jensenracing77's Avatar
just look at every thing as many little projects. take lots of pictures. i also get a couple hundred zip lock bags. when you take something apart put all the bolts to that part into a bag and mark it for what it came off of. like rear end bolts in one bag, grill bolts and screws into another bag, door hinge bolts into another..... it is not that hard but just hard to man handle the body after it is off.
jensenracing77 is offline
Old January 27th, 2010, 12:37 PM
Getting There
Ranzan's Avatar
Like everyone has said pictures pictures and more pictures... service manual is a must also lots of bags for parts
I also catagorized in boxes after I bagged my parts
Ranzan is offline
Old January 27th, 2010, 12:44 PM
"It's like eating an elephant one bite at a time"-Richard gearheads78
Old February 2nd, 2010, 08:23 AM
firefrost gold's Avatar
Im looking at the same thing are you thinking if You pull gas tank and lines and brake lines, steering can you lift body off and roll it out strip it paint or coat it rebush it and roll it back then put body back on .? I have wondered how to lift body with out hurting it I have seen lifts on line that use your engine hoist to lift the body ? dont now if it a good deal or set up or not . Can you put 4by 4 under the car and the frame in 3 or four spots and then jack it up all the way around then roll out frame and re set up under frame mounts can you rent a lifter after it is off to clean bottom or do you have to buy them ?
firefrost gold is offline
Old February 2nd, 2010, 02:14 PM
14 body bushings/ 2 radiator housing bushings, fuel tank, steering gear, rear shocks,possibly some exhaust, and some wiring!!! A couple of good floor jacks and jack stands, and yes pictures pictures, pictures!!!!!
oldcutlass is online now
Old February 2nd, 2010, 02:18 PM
car guy
gearheads78's Avatar
Its easier to take the body off the frame....
gearheads78 is offline
Old February 2nd, 2010, 02:24 PM
Good point!!!
Old July 3rd, 2016, 07:12 PM
rr480's Avatar
Take plenty of pics and don't forget the e brake cable,it will be a lot harder putting it back, do your home work
Get some good a strong 4x4 and concrete blocks
Pull it out when the body is high enough
rr480 is offline
Old July 3rd, 2016, 07:35 PM
Phantom Phixer
Charlie Jones's Avatar
If you can get the use of a twin post lift , it works really slick.
You'll have to get or build a body cart or rotissirie to keep the body on , unless you want to (or even can) tie up the hoist while you work on the frame.
Don't forget to properly brace convertible ( and very rusty hardtop) bodies, before lifting.
https://classicoldsmobile.com/forums...off-frame.html
Charlie Jones is online now
Old July 5th, 2016, 06:25 AM
a-merry-can's Avatar
I just took my body off this weekend. The e-brake cable was a MAJOR PITA! I ended up cutting it. It's worth the $35 to never touch that thing again. :-)
a-merry-can is offline
Old July 5th, 2016, 10:36 AM
Nice support pics guys. You do know this thread is over 6 years old?
Allan R is offline
Old July 5th, 2016, 07:17 PM
Eddie Hansen's Avatar
So is mine lmao. As far as removing the body I like two engine hoists and use spreader bars
Eddie Hansen is offline
Old September 25th, 2016, 12:12 PM
J.O.'s Avatar
Pictured are two alternatives to removing your body from the frame.
Front end loader with forks.
Lift truck with ten foot spreader was no sweat.
J.O. is offline
Old September 25th, 2016, 12:30 PM
rr480's Avatar
I wished I had that set up!!
rr480 is offline
Old September 25th, 2016, 03:55 PM
Rocket Renegade!
What do you wish now?
BangScreech4-4-2 is offline
Allan R
July 2nd, 2011 10:01 PM
sixty9olds
June 14th, 2011 06:43 PM
1969goatman
August 30th, 2010 07:44 PM
real442
May 23rd, 2008 05:57 AM
DJMatthews
December 5th, 2006 01:28 PM
Quick Reply: How to get my frame off the body?
