How do I tackle frame bends/dents?
Old July 5th, 2016, 06:29 AM
a-merry-can's Avatar
Hi guys,
I finally got my body off the frame last night and noticed that the bottom edge of the frame has some dents in it behind the crossmember. I'm guessing it was from poor jack location. It doesn't seem to have affected the frame geometry in any way, but since I'm going to this effort, how should I tackle pulling these out? I imagine this is a common problem?
a-merry-can is offline
Old July 5th, 2016, 11:43 AM
TripDeuces's Avatar
Put a big Crescent wrench on it and bend it straight. A big hammer might come in handy too.
TripDeuces is offline
Old July 5th, 2016, 12:18 PM
frankr442's Avatar
A friend of mine would say "heat and beat".
frankr442 is offline
Old July 5th, 2016, 07:06 PM
Eddie Hansen's Avatar
I would suggest maybe putting a piece of square tubing underneath it use some big c clamps then you have a straight edge to gauge your progress you may be able to heat the metal and draw it down with clamps and hammer?
Eddie Hansen is offline
Old July 5th, 2016, 07:30 PM
Cool. Thanks for the tips. I'll try a few of these this week. Even if I only pull out the big dents, it'll be better than what I have.
Old July 6th, 2016, 09:08 AM
Exactly how I did it, though I needed a piece of pipe over the end of the wrench.
joe_padavano is offline
Old July 9th, 2016, 05:11 AM
Funkwagon455's Avatar
I made a straightening tool from a piece of 1" square tubing welded to a piece of 3/8 plate, then bolted a second plate to the first. Very simple,very effective
Funkwagon455 is online now
Old July 9th, 2016, 05:17 AM
Ryan 1969 Chevelle SS396's Avatar
Very nice home made straightener!!
I like all the suggestions except heat, I think that should be a last resort.
Ryan
Ryan 1969 Chevelle SS396 is offline
Old July 9th, 2016, 05:18 AM
Looks like the fuel lines are the same as my car, 3/8 and 1/4 return?
What car?
Ryan
Old August 20th, 2016, 09:02 PM
marxjunk's Avatar
it wasnt hot when i got bent..why does it need to be to straighten it..
heat is a last resort..
marxjunk is offline
Old August 23rd, 2016, 06:04 AM
Oldsdruid
rocketraider's Avatar
Olds used 3/8" supply lines on all V8s where Chevy used it only on big-block cars.
rocketraider is online now
L77F85
August 29th, 2015 01:06 PM
Oldssupreme
February 25th, 2013 11:24 AM
Ranmat
February 2nd, 2013 09:47 AM
Xavier777
January 25th, 2013 05:28 PM
deflepnut2003
April 26th, 2012 07:50 PM
Quick Reply: How do I tackle frame bends/dents?
