Greasing 1968 olds 442 hood hinges and springs?
Old August 4th, 2018, 10:54 AM
Frisbee_k9's Avatar
What is the grease to use on 1968 olds 442 hood hinges and springs?
Frisbee_k9 is offline
Old August 4th, 2018, 12:29 PM
I use a drop of 3in1 oil. Don't over lube them because the hood may not stay up.
oldcutlass is offline
Old August 4th, 2018, 06:59 PM
Frisbee_k9's Avatar
ah 3in 1 oil got it. I was thinking heavier grease type of lube. Cool thanks
Old August 4th, 2018, 07:50 PM
The springs are sized to hold the hood open even if there is zero friction in the pivots.
As for lube, I use lithium grease in a spray can. This can get messy, so you want to use the small "straw" that comes with the can.
joe_padavano is offline
Old August 4th, 2018, 08:21 PM
Sugar Bear's Avatar
Oil is good for getting into places where grease will not penetrate. Use oil to get into the large rivet like hinge points and white grease when you can get it directly on the point of friction/slide.
Good luck!!!
Sugar Bear is offline
Old August 4th, 2018, 09:18 PM
Remember though, oil moves and grease does not. Lots of my gun stocks get oil tracks from the wipe down oil moving over time.
Koda is offline
Old August 4th, 2018, 11:50 PM
Gerald Nickels's Avatar
I always use engine oil in a can. Look at the 70's Chevy trucks the hood will bend at the hinge if not oiled.
Gerald
Gerald Nickels is offline
Old August 5th, 2018, 01:41 AM
Inline's Avatar
Quess theres as many ways as guys, i personally use ATF
Inline is offline
Old August 5th, 2018, 05:57 AM
Frisbee_k9's Avatar
Thanks Joe P see you oncthe 11th
thanks Joe.
Old August 5th, 2018, 01:02 PM
Frisbee_k9's Avatar
thanks Eric. I appreciate the help.
teamwieland
August 17th, 2018 11:23 AM
Racer_X
August 4th, 2018 08:46 AM
1968CutlassSupreme
Body work
17
June 30th, 2017 02:12 AM
Stevec
August 18th, 2016 12:11 PM
November 6th, 2009 06:14 PM
Quick Reply: Greasing 1968 olds 442 hood hinges and springs?
