Coil spring supplier recomendation & 1" drop
Old December 12th, 2014, 01:28 PM
62 Cutlass Convert's Avatar
I have a 62 F85 Cutlass Convertible. It sat for 40 years on the susp in storage and I will be replacing springs and shocks. I have never had the car on the road and don't really know where it rides on standard springs . The only spring offered by anyone is the standard springs with no HD option other than the rear station wagon springs which are 237Rate vs the other models at 160Rate. Fronts are the same for all models. No Moog available but Eaton Detroit Spring has a them at $250 and Fusick at $160. Eaton can also supply a 1" lowered spring which will have a stiffer rating/lower deflection/lower center of gravity for vehicle/less lean/better handling. Putting 205x60 or 65 x 15s on it.
Question is, any preference for Eaton vs. Fusick for the money? And anyone know if the car can handle a 1" drop and still align.
The tire size appears to clear but may be an issue with lowered springs and I'll be looking at that also.
Any thoughts on these issues are appreciated.
62 Cutlass Convert is offline
Old December 16th, 2014, 11:21 AM
Anyone?
Old December 16th, 2014, 11:29 AM
Beer Connoisseur
70cutty's Avatar
Before I went with air bags I had eaton 2" drop springs on my impala. They are definetly worth the money. It drove as comfortable as stock if not better.
70cutty is offline
Old December 16th, 2014, 04:54 PM
Appreciate it, hanks for the info. Any issues with getting into alignment? How did the lowered spring ride height compare to the original, I guess worn out spring ride height?
Old December 16th, 2014, 06:39 PM
Beer Connoisseur
70cutty's Avatar
The alignment wasn't an issue, ride height compared to worn out stock springs was almost identical with a 2" drop, maybe a 1/2" lower.
That's why I went with air bags. Love the way it rides now.
70cutty is offline
Old December 18th, 2014, 08:26 AM
Thanks for the info. Sounds like ride height might be about right since tires clear with the old springs.
Sorry, maybe I am not understanding, but if it drove well with the 2" drop springs why did you go to air bags?
Anyone with experience with new springs on a 61-63 F85/cutlass?
Old December 18th, 2014, 01:31 PM
Beer Connoisseur
70cutty's Avatar
I wanted it lower, I was kind of disappointed when I put the springs on and ride height didn't change much.
70cutty is offline
Old December 18th, 2014, 03:15 PM
Registered car nut
nonhog's Avatar
Best be patient, not many of these cars around. IMO. Most seem to be original. Your probably on your own.
Good luck!
nonhog is offline
Old December 18th, 2014, 04:42 PM
Patience is a virtue, or at least necessary, with info and parts for these cars. Appreciate the feedback you guys. That Impala is a bad looking ride, low and wide.
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
panos
16
April 29th, 2010 12:49 PM
RAMBOW
May 21st, 2009 12:08 PM
Longhorncutlass
March 2nd, 2009 01:53 PM
Quick Reply: Coil spring supplier recomendation & 1" drop
