1969 non tilt cutlass AT steering column
I have a question about the parts in the upper column. When I removed the steering Wheel it looks like i'm missing some parts, and i'm unsure of how the short spring should fit. Spring before the horn contakt ring or after?
The short stiff spring goes UNDER the grey (or greenish..can't tell exact color)plastic piece in your pic (which I assume you're referring to as the "contact ring"). That plastic piece is called the "cancelling cam" not the horn contact ring (which is something completely different).
So.....spring, cancelling cam, lock plate, small wire retainer ring (you may need a tool to depress the lock plate, etc to install it easier), etc
EDIT: the plastic piece I'm referring to (cancelling cam) is shown in your SECOND picture.
Stanley
Stanley
starfire
December 9th, 2021 08:21 PM
pfergy600
July 22nd, 2014 05:27 PM
317Cutty
June 18th, 2014 10:53 AM
70Post
January 29th, 2014 10:49 AM
ELECMAN
January 22nd, 2012 01:49 PM
