1968 dash panel
Old February 12th, 2016, 02:03 PM
bob klein's Avatar
1968 dash panel
would a steel dash panel from a 69 cutlass be the same as that of a 68 cutlass. mine is rusted where the windshield seals to it. thanks.
bob klein is offline
Old February 12th, 2016, 02:14 PM
2blu442's Avatar
Hi Bob
I think they are the same, someone else who knows for sure will need to verify. But the fact you have a convertible also may need to be mentioned. I know the 70-72 wagon and 4 door use a different windshield than the 2 door. I don't know where the convertible falls in there. John
2blu442 is online now
Old February 12th, 2016, 04:52 PM
Indy_68_S's Avatar
If the rust is just under where the windshield sits, you can patch it several different ways.
Mine was bad.
But with a combination of the widely available patch piece and some creative metal work, it's now good as new. Might be easier than trying to spice in a whole dash.
Indy_68_S is offline
Old February 12th, 2016, 05:39 PM
allyolds68's Avatar
The rust is usually in the cowl too as Indy_68_S has shown in his pic above. Mine was about the same as his. I patched the cowl and I made a patch panel and welded it in where the dash was rusted. Is your rust as high as the speaker grille? If it's below then it can be fixed without a new dash.
allyolds68 is offline
Old February 12th, 2016, 05:58 PM
bob klein's Avatar
The rust is pretty extensive, much more than in the pic above. Patching in a new piece is certainly an option but I have a line on one from a 69 and would rather go that route if its the same as my 68.
Bob
Old February 12th, 2016, 08:25 PM
68442's Avatar
68-72 is the same sheetmetal frame. 70-72 frame will have an additional hole to bolt the passenger leg of the dash pad that the 68-69 pad doesn't cover. However this will not effect your 69 dash doner.
68442 is online now
Old February 13th, 2016, 06:34 AM
allyolds68's Avatar
Are you sure about that? 70-72 doesn't have the slots in the top of the dash metal like 68-69 does and on the passenger side above the glove box it appears to be different. I can't even remember if those slots do anything. I've never seen a 68-69 dash installed in a 70-72 or visa-versa. Not to say that it couldn't be done but a dash metal replacement is a major job with a lot of spot welds to be drilled out. I'd be more comfortable with a 68 or 69 dash which I know are the same.
Old February 13th, 2016, 11:08 AM
68442's Avatar
I guess what i should have done was stick to the OP question. Which is yes the 69 dash will work drop in. And not get into the 70-72 dash chassis. There are a few more suttle differences other than the hole i mentioned but didn't want to take off on an unrelated topic. Kind of like saying 68-72 car frames are all the same. Which they are not yet will fit all years.
68442 is online now
m1369d
Body work
February 15th, 2014 12:41 PM
ThePackRat
January 2nd, 2014 08:52 PM
onofre442
December 1st, 2013 10:36 AM
68RocketAction
May 31st, 2013 09:06 PM
Jay D
Body work
November 17th, 2012 03:26 PM
Quick Reply: 1968 dash panel
