1963 F 85 Stock barn find
Old August 4th, 2013, 06:27 PM
Crusty's Avatar
I have to sell my 63, I bought it this year, and cannot do anything with it.
It runs, and goes into gear. I did not drive it due to leaks in the brake line.
The fuel tank has several pin holes in it, I dont think it can be salvaged.
The front floor pans are rusted in the typical spot, by the fresh air vents.
I can provide more specific pictures if needed.
I live in Cincinnati, Ohio. $1500 firm.
Crusty is offline
Old August 4th, 2013, 09:57 PM
Price? Motor?
slantflat is offline
Old August 5th, 2013, 07:22 AM
Price? Motor?
Motor will be the 215. That was the only option in these cars. Price is in his original post.
joe_padavano is offline
Old August 5th, 2013, 07:55 AM
Grace Stinespring-Welch's Avatar
as long as the frame is still solid, it can be fixed,and restored.
Grace Stinespring-Welch is offline
Old August 5th, 2013, 08:07 AM
The 61-63 cars are unibody. There is no frame.
Old August 5th, 2013, 08:13 AM
59-59-59's Avatar
This is turning out to be one of the funnier threads on here!
59-59-59 is offline
Old August 5th, 2013, 08:20 AM
i didn't know that. thanks.
Old August 5th, 2013, 09:01 AM
jaunty75's Avatar
Brake line leaks are an easy fix. Replace the brake lines.
Fuel tank pinholes are actually easy to fix, too, if that's really all that the problem is and they really are pinholes. They sell stuff you can put over the pinhole to seal it. I had a pinhole leak in the tank of a '64 Jetstar I once owned, and it took five minutes to fix. Never leaked again in the five years I owned the car.
Of course, if the tank looks like Swiss cheese or if the pinholes are really just the thinnest places where rust has occurred, then this may not work. But I wouldn't give up on that tank without further inspection as replacements are not made new, and used, good ones are difficult to come by.
Permatex 12020 Instant Gas Tank Repair, 1 oz. stick : Amazon.com : Automotive Permatex 12020 Instant Gas Tank Repair, 1 oz. stick : Amazon.com : Automotive
jaunty75 is online now
Old August 5th, 2013, 10:01 AM
keith49's Avatar
tank
I can get brand new replacement for my 64' for about $125 shipped
keith49 is offline
Old August 5th, 2013, 04:42 PM
And yet, you can't get one for a 61-63 F-85 at any price, which is what this thread is about.
Old August 5th, 2013, 06:52 PM
I knew that, I don't know why I wrote that. I'm sorry guys.
Old August 5th, 2013, 07:09 PM
Crusty's Avatar
Funny stuff-- Read this Joe P.
Thanks for all the help Joe, really. This is a kinda funny post, I laughed out loud.
If the car does not sell when the snow flies, I will pull it in the garage and begin the process of parting it out. Joe, you got DIBS on the trunk lid if your still interested in it.
Crusty is offline
Old August 6th, 2013, 10:19 AM
rocketman77's Avatar
LOL. Glad to know we car junkies can have something to browse and laugh at during lunch besides our bosses. I needed a good laugh today. Work is a drag, need to go home!
rocketman77 is offline
Old August 6th, 2013, 02:52 PM
Ancient Iron's Avatar
They have a subframe like a Camaro
Ancient Iron is offline
Old August 6th, 2013, 03:09 PM
No, they do not. They have a very small suspension crossmember that runs from side to side and holds the control arms and springs. This is really nothing like a Camaro subframe.
F-85/Jetfire suspension crossmember:
100_9481.jpg?t=1343948180
Camaro subframe:
The Camaro subframe rails are about eight feet long. There are no subframe rails on the F-85 crossmember. It simply runs side-to-side under the engine and mounts the suspension.
Old August 6th, 2013, 03:43 PM
Yes, these are unique little Oldsmobiles with a small following.
oldcutlass is online now
Old August 6th, 2013, 08:19 PM
Camaro subframe:
Old August 6th, 2013, 08:20 PM
Nothing like a Camaro subframe ??????????? Ok
Old August 6th, 2013, 09:15 PM
Camaro subframe:
Gee, that sure looks a lot like a Nova subframe...
MDchanic is offline
Old August 7th, 2013, 05:06 PM
64Rocket's Avatar
I have a repairable gas tank for a '63
Not rusty, just a couple of dents.
Gene
64Rocket is offline
Old August 8th, 2013, 09:39 AM
Nope. The Camaro subframe bolts to the body in several places along those rails behind the crossmember AND it extends forward of the crossmember, mounting the front fenders and core support. The Camaro subframe carries longitudinal bending loads.
The F-85 uses a simple crossmember with THREE attach points to the body, one behind each wheel and one at the center front under the radiator. This crossmember does NOT carry any longitudinal bending loads (because it CAN'T by design). The core support and inner fenders are structural members in the F-85, welded in place at the factory. They are NOT structural in the Camaro, as the subframe carries those loads. That's a very fundamental difference in how the two cars are built.
Old August 9th, 2013, 07:27 PM
olds3442's Avatar
63 cutlass
Joe, since you know a lot about these things do you got to do major work to install a 455 in one , if building a race car can you tie frame together been thinking about building one but I don't want to do a whole chassis, also what do they weigh thanks
olds3442 is offline
Old August 11th, 2013, 09:26 AM
See my response to your PM. Also go back up and reread this thread where I say that there are NO subframes to tie together. This car is pure unibody, not a semi-unibody like a Camaro. Also read the thread that I provided the link to in the PM. These cars weigh 2600-2700 lbs. The 455 will increase that to over 3000 lbs, BEFORE you account for the heavier trans, rear end, brakes, and suspension. At that point you'll weigh the same as a 64-67 A-body.
Old August 11th, 2013, 10:05 AM
olds3442's Avatar
Joe ,thanks for great info, looks like tube chassis is the best route,i already have a tube chassis 68 so I guess I will have to pass on one of these builds to much time and money, John
olds3442 is offline
Old September 30th, 2013, 04:12 AM
63f85droptop's Avatar
PM'd you. Im interested in this car if you still have it.
63f85droptop is offline
1962oldsguy
March 18th, 2014 07:53 PM
TylerW
February 14th, 2013 02:41 AM
trackz man
March 5th, 2011 01:30 PM
Atdog
June 15th, 2008 01:25 AM
Mr. King
February 12th, 2007 08:51 AM
Quick Reply: 1963 F 85 Stock barn find
