1972 Oldsmobile Cutlass
Old August 26th, 2013, 08:27 AM
Platinum Sponsor
ccnclassicoldsmobile's Avatar
I have a 1972 olds 442 w-29 it has a brand new 455 .030 over forged flat top pistons plasma moly rings arp head bolt arp main studs arp rod bolts the motor is 10.5.1 factory c heads all brand new swirl polished 1 piece valves 2.072 int. and 1.61 exh. double springs roller rockers comp 305h hydrolic cam cloyes true double roller morrosso 8 qt deep chrome pan morrosso pickup screen melling oil pump chrome moly shaft b cool 4 row aluminum radiator with duel 14" electric fans on there own relay msd pro billit distributor msd cap rotor digital 6al box msd hvc coil msd 8.8 wires optima red top Dakota digital dash done in red new tci th400 trans red clutches tci aluminum deep cast pan 8.5 inch eaton high tourq posi unit Richmond 3.73 gears moser 33 spline axles all new bearings slotted and drilled rotors recipts for everything much more...holy chrome ultra hp 850 carb car runs 180 all day in 90 degrees in traffic
http://www.collectorcarnation.com/Cu...html?aid=32795
ccnclassicoldsmobile is offline
travisbeamon
April 6th, 2013 09:37 AM
kenn
Cars Wanted
September 9th, 2009 03:46 PM
jonstringer
May 28th, 2009 12:47 PM
vanman
March 2nd, 2008 05:58 AM
MB3110
August 20th, 2006 04:41 PM
Quick Reply: 1972 Oldsmobile Cutlass
