Care and Appearance Washing, waxing, paint care products, etc.
Clean/wax 30yr old paint
Old July 20th, 2014, 08:33 AM
Billyboy746's Avatar
Got any ideas? I have a 70 cutlass that has red paint with black race stripes and pin stripes. The paint is 30 yes old with some minor cracking on the doors. Is there something relatively easy to use to buff the paint and clean it up prior to waxing?
I have used Meguires #7 wax. The paint does shine but looks like a dull shine. Anyone have experience with aged paint?
Billyboy746 is offline
Old July 20th, 2014, 11:12 AM
Proud Viet Nam Veteran
redoldsman's Avatar
The first thing would use on it would be a Mother's Clay Bar. It removes all the impurities in the paint. Then I would follow with one of their carnuba waxes.
redoldsman is offline
Old July 20th, 2014, 11:15 AM
Shaking out the cobwebs..
midrange's Avatar
I second the clay bar and carnuba wax follow up.
midrange is offline
Old July 20th, 2014, 12:18 PM
ELY442's Avatar
If you dont like to use the paste wax, try using the spray wax. Just spray and wipe. I use Mothers FX spray wax.
ELY442 is offline
Old July 20th, 2014, 01:25 PM
Ctls442's Avatar
I have had good luck using Color Back Finish Restorer on dull, tired older paint. I believe it is made by Turtle Wax.
Ctls442 is offline
Old July 20th, 2014, 03:53 PM
Rocketowner's Avatar
If you have access to a circular auto Buffer,then get you some Pro Troubleshooter (Available online by the gallon for $30 ) take your time and Don't bear down on the edges of any panel. If it is possible to bring it back to a good shine , this will do it.Once you get the shine you want then use any good pure Carnuba wax ,to retain the shine. Don't use a regular electric circular sander ,they turn much faster than a polishing buffer. Good luck, Larry
P.S my car is 59 years old and the green paint that you see is the original Lacquer ,and the Troubleshooter brought the shine back about 9 years ago and it's only been waxed with Carnuba wax since!
Rocketowner is offline
ralsy
June 16th, 2014 07:49 PM
chip-powell
March 21st, 2014 06:54 AM
slumpy
Care and Appearance
March 6th, 2010 11:02 AM
Allan R
July 25th, 2009 05:53 PM
awspeich
March 28th, 2007 10:35 AM
Quick Reply: Clean/wax 30yr old paint
