Care and Appearance Washing, waxing, paint care products, etc.
Restoring plastic inner guards
Old October 5th, 2014, 10:43 PM
Acceleratii maxim rapidus
73aussie455's Avatar
I've been detailing all the usual under the hood, firewall, brake booster, air cleaner, brackets, hoses etc, and am looking for a solution to restore the finish to the plastic inner guards.
Everything i've tried leaves a dull or patchy finish. I'm not after a concourse result, just a consistent finish.
I've tried; Plexus (plastic cleaner & polish), kitchen cleaner(spray & wipe), Armourall, turps, metho, soapy water and tire shine.
My last resort is to mask it all up and use satin black spray paint. (not ideal)
Any ideas? Thanks.
73aussie455 is offline
Old October 6th, 2014, 01:02 AM
Yellowstatue's Avatar
If they are clean and all the dirt is off, try a good quality boot polish. However there are other threads here that address this specific problem.
Yellowstatue is offline
Old October 6th, 2014, 01:51 AM
Thanks for that, found the info
Old October 12th, 2014, 05:01 PM
jpc647's Avatar
What'd you find out? And how did it turn out.
jpc647 is offline
Old October 13th, 2014, 01:23 AM
I found lots of threads on cleaning and restoring engine bay plastics, this is probably one of the best;
https://classicoldsmobile.com/forums...mpartment.html
I really didn't want to paint with SEM or a plastic/vinyl restorer.
Ended up persevering with the same stuff I use on my race bike, PLEXUS plastic protectant, cleaner and polish, made in the US.
http://www.plexusplasticcleaner.com/about.html
Seems to work great, stripped the crud right off and left the original colour. I had to get a little aggressive where the A/C clutch sprayed grease/oil in a line next to the compressor for the last 40 yrs and there are a few abrasions where pipes have been rubbing, but I will leave it as is. Very pleased with the result.
I've used it on all the under hood plastic and external body plastic.
jensenracing77
January 9th, 2012 06:38 AM
commwog
October 15th, 2011 08:51 PM
davebw31
March 25th, 2011 06:55 AM
guycaso
February 1st, 2011 12:27 PM
72rocket
January 13th, 2008 02:39 PM
Quick Reply: Restoring plastic inner guards
