Care and Appearance Washing, waxing, paint care products, etc.
aluminum intake
Old January 24th, 2012, 05:44 PM
72hurst's Avatar
aluminum intake
I have an aluminum intake that I can't seem to get clean. It doesn't have any oil or girime it just doesn't look clean. As if it had some sort of oxidation. What is the best way to clean it?
72hurst is offline
Old January 24th, 2012, 06:57 PM
Olds Dreamer
alek72us's Avatar
if u can take it off have it sand blasted then clear coated. or u can try a wire wheel or wire brush.
alek72us is offline
Old January 25th, 2012, 04:23 AM
firefrost gold's Avatar
You can try some aluminum wheel cleaner with muriatic acid in it alittle goes along way. Then top coat after it is dry .
firefrost gold is offline
Old January 25th, 2012, 04:45 AM
Dave Siltman's Avatar
If you want a truely factory appearance send it to Jerry MacNeish at Camaro-Highperformance. If it is in need of any repair he can handle that, too. Depending on what kind of intake it is (factory vs. aftermarket) the cost to re-furbish might be more than it's worth.
Jerry's work is the best and is has been judged as such.
Dave Siltman is offline
Old January 25th, 2012, 07:25 AM
frankr442's Avatar
I had mine glass beaded (sand is too violent). Every couple of months I wipe it down with GM heat riser lube #88862627. It gives it a nice natural sheen and keeps it from oxidizing. I love that stuff, it cleans and its the best lube I've tried. I use it on the alternator also.
frankr442 is offline
tocicar8825
September 21st, 2021 07:10 AM
TIM FISKUS
May 12th, 2013 05:17 AM
svnt442
July 17th, 2011 04:43 PM
blonzz
October 25th, 2004 02:19 PM
Quick Reply: aluminum intake
