Power booster pushrod
I may have to change my 11 in. power disc brake booster to a dual diaphragm 8 in. booster to fit the 455 into the 64 Vista. Will the pushrod from the brake pedal I have now still work with the 8 in. booster? Thanks. Ron
May have to egg shape the mounting holes a bit on the master cylinder, if the mount studs on the booster are a little off from the master cylinder mount hole spacing. Wont hurt a thing.
If you have tall aftermarket valve covers, all bets are off. In that case, I'd go with a hydroboost.
slw0501
Brakes/Hydraulic Systems
October 12th, 2015 01:55 PM
RAMBOW
February 2nd, 2015 05:07 PM
zodiacblueS
44
October 12th, 2014 03:22 PM
