Power booster pushrod
Old November 2nd, 2016, 08:28 PM
rcwjr's Avatar
I may have to change my 11 in. power disc brake booster to a dual diaphragm 8 in. booster to fit the 455 into the 64 Vista. Will the pushrod from the brake pedal I have now still work with the 8 in. booster? Thanks. Ron
rcwjr is offline
Old November 3rd, 2016, 12:15 AM
Firewalker's Avatar
Should, but check adjustment. They usually screw in or out.
May have to egg shape the mounting holes a bit on the master cylinder, if the mount studs on the booster are a little off from the master cylinder mount hole spacing. Wont hurt a thing.
Firewalker is offline
Old November 3rd, 2016, 06:02 AM
Why? The identical 1965-67 cars came with BBO and power brakes from the factory. The 64-66 cars used 9" boosters that fit the BBO without notched valve covers. The 67 cars used the same 11" booster as the 68-72 cars and did use a notched cover on the driver's side.
If you have tall aftermarket valve covers, all bets are off. In that case, I'd go with a hydroboost.
joe_padavano is offline
slw0501
Brakes/Hydraulic Systems
October 12th, 2015 01:55 PM
RAMBOW
February 2nd, 2015 05:07 PM
zodiacblueS
44
October 12th, 2014 03:22 PM
jc83
March 22nd, 2010 04:33 PM
54olds
March 31st, 2008 06:07 PM
Quick Reply: Power booster pushrod
