Would this brake conversion set fit on my 69 Cutlass conv.
I am planning to change from drum to disk on the front. Now I found an interesting set on ebay. So I wonder if this is a fitting bolt on set, and what else I need.
http://www.ebay.com/itm/Wilwood-Forg...e1e708&vxp=mtr
Let me know what you think.
Regards,
Tom
Regards,
Tom
According to the ad, it appears they have both disc and drum brake application, but the description is way too vague for me... I'd need more info from the supplier than what shows up in that listing. Have you contacted the seller and asked for more info?
The nice thing is there's no appreciable increase to the offset, which seems to be a stumbling block with so many of Wilwood's kits...
I think that in Germany you'll have enough trouble getting replacement parts for stock brakes, never mind parts for a one-off aftermarket conversion. More to the point, those rotors aren't any larger than stock. The four piston calipers likely won't clear SSII/III wheels. I'd suggest a stock disk conversion. If you want to upgrade the calipers, get the new dual piston D52 calipers that are available at most aftermarket brake vendors.
Hi Joe,
I guess you are one of the masters here ;-). Partwise, I'll have orders shipped to a friend and he shipps the surface to me, or one of my buddies comes over.
I have the SSII wheels (with bolt on center caps) and 15" tires, so I think my rims are 15" as well. Could you recommend a conversion set which has hall and may be below 1000$ but good performance?
Regards,
Tom
Regards,
Tom
Hi Joe,
Regards,
Tom
Regards,
Tom
http://inlinetube.com/disc%20brake%2...on/DBK6807.htm
Hi Joe,
Regards,
Tom
Regards,
Tom
Hi Joe,
thanks for the thread, would you know about four piston calipers which fit under my 15" rims?
@henryk8398: the IT kit might be good, but I read lots of complaint about IT, so I rather look somewhere else
Thank you,
Tom
Thank you,
Tom
Wilwood makes a two-piston D52 caliper that's a direct replacement for the 69-up caliper, but their website only says that it clears MOST 15" wheels. Unfortunately, the SSII/III wheels seem to be the perpetual exception. I don't have dimensions but the caliper looks a little larger than the factory single piston one.
Hi Joe,
I'll contact wilwood to see what they say. One more question about the rim. I am sorry, but today I double checked what the tire says. I was wrong about 15" it is a Summit GT Radial Track with P245/60R14/98S, so I believe it is a 14" rim, does this make any difference to the things we discussed before? But the rim caps are screwn on, I could feel the bolts on the rims backside.
Thanks,
Tom
Yeah, it kinda has to be.
Nope. No difference whatsoever. All factory SSII/III wheels (14" or 15", 6" wide or 7" wide) clear the factory disc brakes. Again, no guarantees on aftermarket brakes or calipers.
...does this make any difference to the things we discussed before? But the rim caps are screwn on, I could feel the bolts on the rims backside.
jag1886
March 17th, 2018 12:12 PM
W-27
October 5th, 2016 08:34 PM
wired
Brakes/Hydraulic Systems
September 12th, 2009 08:11 AM
