Front drum brakes
Old December 30th, 2016, 06:40 AM
Ingraham's Avatar
Front drum brakes
I have a 62 dynamic, the front drums are seized. I have tried everything I know short of drilling out the holding pins and removing the wheel cylinder bolts. Any ideas that will help?
Ingraham is offline
Old December 30th, 2016, 06:56 AM
m371961's Avatar
Have you removed the outer wheel bearing? Are you saying it will not turn?
What have you tried?
m371961 is offline
Old December 30th, 2016, 08:03 AM
Why haven't you disconnected the brake line, unscrewed the cylinder screws, and cut the heads off of the retaining pins (all you usually need to do is to grab the heads with a pair of nippers and use a hacksaw blade or a whizzer, or just give a good squeeze on the nippers)?
If the shoes are stuck to the drums, or just can't be retracted out of the wear groove, it's pretty much the only way, and it's easy.
MDchanic is offline
Old December 30th, 2016, 11:07 AM
m371961's Avatar
Not knowing your experience, you are not trying to remove the drum like the rear drum comes off, right?
m371961 is offline
72oldspa
Brakes/Hydraulic Systems
April 8th, 2014 11:13 AM
delta254
January 27th, 2013 08:11 AM
1carsick
23
October 2nd, 2012 05:50 PM
phil7395
January 1st, 2012 06:19 AM
Quick Reply: Front drum brakes
