Brakes locking up after getting warm
#41
Non adjustable booster push rod on my Delco booster.
For reference, my setup
If anyone interested, here is my restomod thread from 2012 on...I will be updating it this week with work done over the past 5 months.
What's hilarious about this car is it started out as a general decent driver fix up to a full out complete restore...how did that happen again?! The MAWs just took over and had it's way with me...
71' Cutlass S frame off restore
#42
Better to have just a little bit of slack/distance between brake booster push rod & MC piston pushrod - that 1/16” you already read about. So, error on being a tad looser than too tight. Recall you had a little bit of play in your brake pedal assembly and shimming to the point of no play might be a good point. I’d probably go with ~5mm-10mm shim. Better to ensure the MC piston push rod can return to its normal position with no preload so it can properly relieve pressure inside the MC.
#43
Yes your booster has a non-adjustable push-rod, it's the same re-pop with the "Delco" stamping that I have. The rod does come out,you'll have to carefully pull it straight out with pliers,then you can trim it down. I didn't want to use shims or washers as dirt or water might be able to get in between the two. It took a couple of tries (trimming & testing,you obviously don't want to take too much off & end up with too much free-play.
#44
For now the 1mm shim worked. Took it for a good drive today and no dragging. I will consider going another 1 mm just for good measure as Chief suggests... though I'm not thinking I need 5mm at this point.
Big thx to all and hope this helps out the next guy who comes across this problem.
