Brake bleeding problem
Old October 4th, 2017, 07:19 PM
richeyb's Avatar
I'm attempting to bleed the brakes on my 1972 Cutlass. I can losened all the bleed bolts except the front left bleed bolt. I think I have tried all the tricks But I'm afraid of round the bolt. Any suggestions. The bolt is surrounded and won't allow use of a socket or normal box end wrench....
richeyb is offline
Old October 4th, 2017, 08:29 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Have you soaked it with PB Blaster or a mixture of 50/50 ATF and acetone?
redoldsman is offline
Old October 5th, 2017, 04:17 AM
If you stripped it out, remove the wheel cylinder and get the old bleeder out. A new bleeder can be had at your local auto parts store. Reinstall the wheel cylinder and then bleed your brakes.
oldcutlass is online now
Old October 5th, 2017, 07:46 AM
If the bleeder screw is rusted into the wheel cylinder, chances are there is rust in the cylinder also. A brand new front wheel cylinder is a whopping $6 on RockAuto. Don't even screw with the old one.
joe_padavano is online now
Old October 5th, 2017, 07:47 AM
richeyb's Avatar
Yes I've sprayed it with Blaster for about a week 2-3 times a day.....
richeyb is offline
Old October 5th, 2017, 09:50 AM
redoldsman's Avatar
As Joe mentioned, wheel cylinders are real cheap. Now all you have to worry about is getting the hose loose. It would be a good idea to replace both front wheel cylinders and both hoses while you are at it. It is cheap insurance.
Old October 6th, 2017, 01:33 AM
Ozzie's Avatar
The Olds service manual recommends a special offset box end wrench for bleeding (J-21472), but especially if you are working on the original components, I agree with the others. It's probably time to change the cylinder (and probably the hose also). They aren't that expensive, and will save you a lot of grief. If you're a tightwad like me and want to try to salvage the cylinder, do it in a vice, but be prepared to find some bore pitting.
Ozzie is offline
brown7373
Brakes/Hydraulic Systems
March 20th, 2014 06:14 AM
PhilGGG
December 18th, 2013 07:06 PM
Deputy442
September 5th, 2008 05:15 PM
Bluevista
May 21st, 2008 10:20 AM
projectheaven
May 15th, 2008 01:11 PM
Quick Reply: Brake bleeding problem
