Brake bleeding instructions
Old February 1st, 2024, 05:27 PM
Just to make your heads explode, these are both excerpts from Oldsmobile factory-issued Chassis Service Manuals. 1970 on the left, 1985 on the right. Note especially the part in the 1970 manual about "bleed the master cylinder last".
joe_padavano is offline
Old February 1st, 2024, 09:06 PM
Bernhard's Avatar
Wow the one on the left goes against everything I was taught in trade school. The one on the right is what we were taught for non diagonal brake systems. I agree bleeding the master last goes against everything I was taught. That said I did learn a method that was not taught in trade school that worked quite well. Thanks for posting.
Bernhard is offline
Old February 1st, 2024, 09:39 PM
I don't understand the master cylinder bleeding procedure, but I have over time realized it does not matter whether you start with the fronts or the backs as long as they are done in pairs.
oldcutlass is online now
Old February 2nd, 2024, 12:37 AM
^^^This, at least on dual circuit systems that are split front/rear.
Old February 2nd, 2024, 04:25 AM
Interesting. I always learned to bleed farthest to closest.
Olds64 is online now
Old February 2nd, 2024, 05:16 AM
And most of us did from doing single reservoir units.
Old February 2nd, 2024, 07:28 AM
^^ How I learned ^^
Vintage Chief is online now
Old February 2nd, 2024, 10:20 AM
This same discussion is taking place on the AACA forum. This is from a 1969 Motors Manual. Note the GM bleeding orders, considering that Chevy cars for the most part used exactly the same brake system hardware as did other GM cars of that period. Clearly it doesn't matter.
Old February 2nd, 2024, 12:33 PM
mattking's Avatar
I certainly haven't seen everything, but I have never seen a master cylinder with a bleeder valve in any brand.
I too was taught closest to furthest.
This is of course unless it is a volvo 240 then:
1. Left rear
2. Left front, upper, inner
3. Right front, upper, inner
4. Right rear
5. Right front, outer
6. Right front, lower, inner
7. Left front, outer
8. Left front, lower, inner
mattking is offline
Old February 2nd, 2024, 12:48 PM
Seriously? They were original equipment for GMs.
Old February 2nd, 2024, 12:51 PM
Bfg
Bfg's Avatar
That’s odd because most of the master cylinders I’ve seen have bleeder screws. I’ve always bled from the furthest to the closest.
Bfg is offline
Old February 2nd, 2024, 12:54 PM
mattking's Avatar
Never. I see them clearly in your pics but I’ve never seen them in real life. Didn’t know they existed. I bet this will be one of those things that now I have seen them I will see them everywhere
mattking is offline
Old February 2nd, 2024, 02:08 PM
mattking's Avatar
I just got home and for my sanity I checked my Sonoma a Monte Carlo, our 61 studebaker, my 55 Chevy truck, the 64 cutlass and a spare master I have from a 70s Chevy truck
None of them have these bleeders but even my older gm stuff all have replacement masters on them.
would this be something that was dropped from the castings for aftermarket replacement parts?
ive always just bench bled the master and
put it in the car while trying to hook up the lines as fast as possible then bled the brakes at the wheels
I feel like I’ve missed out on a whole new
thing
mattking is offline
Old February 2nd, 2024, 02:12 PM
Most replacement M/Cs do not have bleeder screws. Not only is this a cost savings, but frankly I've never found the need for them, especially with my vacuum bleeder.
Old February 2nd, 2024, 02:25 PM
mattking's Avatar
See, I learn stuff all the time on here.
mattking is offline
Old February 2nd, 2024, 07:00 PM
Bernhard's Avatar
I was always taught furthest away right left rear right left front.
If you install a new master or rebuilt master bench bleed.
I never had a problem getting a solid peddle using this method.
Bernhard is offline
Old February 2nd, 2024, 07:10 PM
Bernhard's Avatar
I agree vacuum bleeding works well.
Bernhard is offline
olds 307 and 403
January 31st, 2023 08:16 AM
joshduty
Brakes/Hydraulic Systems
March 22nd, 2022 07:15 PM
MildBill
January 19th, 2022 06:31 AM
dmw
August 28th, 2021 06:20 PM
rktolds
February 19th, 2018 06:01 PM
Quick Reply: Brake bleeding instructions
