Anyone have original front disc brake calipers?
Old January 8th, 2011, 11:44 AM
oldzy's Avatar
Just wondering if anyone has original front disc brake calipers? I have never seen any. Do they have the part #'s stamped on them? Same quality as the single piston reman stuff today?
What about the Master Cylinder? Same q's as above. thx
I think I would like to get a pair for my 72 Supreme if I can find any, have them rebuilt, etc.
oldzy is offline
Old January 8th, 2011, 01:49 PM
I bleed Oldsmobile
BIGJERR's Avatar
You know I never thought about that when I put a set of remans on a few years ago,Probley should of kept them instead of turning them back in for a core........They are probley on some Chevelle by now,My bad!................Jerr
BIGJERR is offline
Old January 8th, 2011, 02:29 PM
2blu442's Avatar
Ken, I don't know if these are original but here's what came off the 1971 spindles. One is date coded 92 and the other 113. Maybe someone can verify if these numbers would be correct for your 1972 or not. John
2blu442 is offline
Old January 8th, 2011, 04:17 PM
InfoJunkie
InfoJunkie's Avatar
The part # for a Cutlass caliper and a Chevelle are the same number 5472161 thus if you go to your local parts store and buy reman calipers they will be original except fot the date code. Semi-loaded about $22CDN + core.
InfoJunkie is offline
Old January 8th, 2011, 05:05 PM
Registered
Bluevista's Avatar
That's a GM replacement caliper part number, not the original one.
I'm pretty sure those calipers that John pictured are the factory originals, 5473497-L and 5473498-R.
Bluevista is offline
Old January 8th, 2011, 06:05 PM
InfoJunkie
InfoJunkie's Avatar
Replacement part # may be different but casting number is still the same.
Pic is from cardone.com and you can see the 497 and the L same as in John's pic.
Manny
Big red72
April 17th, 2013 07:57 PM
Oldssupreme
February 21st, 2013 10:24 AM
Fear Reborn
December 5th, 2012 05:23 PM
Mike H.
Brakes/Hydraulic Systems
September 27th, 2012 06:49 AM
jhoppeolds
October 13th, 2010 06:22 AM
Quick Reply: Anyone have original front disc brake calipers?
